crankshaft sensor location
08.05.2020 15:27 # 1
flash296
Hi guys ... Does anyone know where the crankshaft sensor is located on the engine? 206 GTI engine!
08.05.2020 15:27 # 2
I don't know if it is the same in GTI, but in the 206's it is between the transmission and the engine. It has a black plastic cover. His head looks towards the front of the car and 3 cables enter. Good luck with.
08.05.2020 15:27 # 3
flash296
Thank you very much, my friend ... I will deal with it on Sunday and clean it and see if it will be fixed. If it doesn't fix, I will change it! Thanks again!
08.05.2020 15:27 # 4
You're welcome. I hope everything will be as you wish. Don't forget to write the results here.
08.05.2020 15:27 # 5
flash296
I just looked at your father. I dismantled the location of the battery, I dismantled the air filter, I couldn't see it again.
08.05.2020 15:27 # 6
muratsafa
If you look from the bottom of the car, you can see easier, you should use a jack
