Crank seal rubbing or whistling sound
08.05.2020 20:36 # 1
emresensoy307
Since I bought my 1.4 petrol lpg li car, I had to go 3 with the shift, but when I threw it at 4, it sounded like a belt rubbing or whistling sound.
08.05.2020 20:36 # 2
ggitaristt
The strap maybe ??
08.05.2020 20:36 # 3
emresensoy307
Maybe I think it is a ball or strap sound, but when it comes to gas pressure, it sounds
08.05.2020 20:36 # 4
hermanito
my teacher, this sound is happening to me in the meantime I researched a little, I came to the conclusion that it is due to balls, belt, exhaust manifold or last muffler
08.05.2020 20:36 # 5
emresensoy307
I changed the last muffler, the exhauster also came from the exhaust, said the sound was still cut
08.05.2020 20:36 # 6
ismailkaya
Does the sound change or the sound stops when the clutch pressure is pressed?
08.05.2020 20:36 # 7
emresensoy307
[QUOTE = ismailkaya] Does the sound change or stop the sound when you press the clutch ;?
[/ QUOTE] yes no sound when throttle, especially in 4-5h when the gear is heard
08.05.2020 20:36 # 8
ismailkaya
This squeaking sound is caused by the dust coming out of the clutch disrupting the clutch ball. these are changing as a set I suggest you change it in service
08.05.2020 20:36 # 9
hermanito
I was watching a video, it came to my mind, this is the sound that comes with me.
08.05.2020 20:36 # 10
bjk1903
Tension Ball / V Belt / Recirculation Pump / Timing I could have skipped the row, but this 4 d is definitely not external.
08.05.2020 20:36 # 11
OguzhanKucuk61
I have the same problem. When he prefers higher than it should be, he does it in 4th and 5th gear. Has anyone reached the solution of the problem?
08.05.2020 20:36 # 12
emresensoy307
[QUOTE = OguzhanKucuk61] I have the same problem. When he prefers higher than it should be, he does it in 4th and 5th gear. Has anyone reached the solution of the problem? [/ QUOTE] this day, I went to the master who left the authorized service, he heard the room heard the sound said that the sound came from the gearbox.
08.05.2020 20:36 # 13
Fikret Adil
I recommend you to change the gearbox oil and try it.
