Cracking sound when starting the car |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee | |
| 15.12.2022 14:15 | # 2 |
get well soon bro, that injector you showed may not be a big problem, if there is a meltdown in the injector washers, there is a compression leak in the vehicle, it starts to work like a compressor, it starts to work like a compressor anyway. km poor quality fuel usage etc. I think you should have your injectors checked. A competent master knows that the original price of those injectors is around 8-10 thousand TL right now..
| 20.12.2022 20:42 | # 3 |
If there is air, the injector washers are worn, it is a material of 3 5 liras. They take a bit of labor but
| 11.02.2023 20:07 | # 4 |
I had it done by my close master friend, it didn't take any labor, it exploded to 2 thousand
| 11.02.2023 23:11 | # 5 |
Let's see, get well soon, good luck with your work
