Cracked Glass Repair
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 15:38 # 1
What is the Accuracy of the Mixture in the Video ....
http://www.hoptek.tv/video-izle/108962/arabanin-catlak-camini-onar Up
gadaş307 2011-06-17 19:54:41
08.05.2020 15:38 # 2
mdincer34
If it is a wonderful thing, but does it have the ability to stick the glass, I wonder if it hits, would it continue to crack like a junk from the rest.
08.05.2020 15:38 # 3
deamod
in terms of appearance this is probably the case?
08.05.2020 15:38 # 4
change is something but the crack in the glass is not scratched, it seems to me or am I wrong
08.05.2020 15:38 # 5
deamod
No, if you look carefully, the crack under the glass is noticeable, so the bilateral crack of the glass is obvious, but I think it just closes this image.
08.05.2020 15:38 # 6
orhanax
Salt, pesticides, alcohol, and water ... I think they're confronted. Sırıtma
08.05.2020 15:38 # 7
I have no idea about the situation in the video. It was so crazy. I can't imagine how accurate ...
I made the repair of the catlag on my glass, but it was not very productive because it filled the soil with dust as it happened 1 year after the catlag. I did not know that something had been done before. If I knew, I would have it done at the beginning.
If I need to explain the process done, the glass resin is used, which fills the glass line and gives the glass solidity. With the help of a special apparatus, it is slowly injected into the catlag. This fluid freezes with ultraviolet heat and becomes fluff.
Let Catlak not get any further, the press is drilled with a thin drill, and an obstacle is placed. And this hole drilled at this liquid filling point facilitates heat.
I had my car glassed for 2 years since I bought my car last summer. I have been traveling for 1 year in a condition that has been repaired. I have not progressed since then ...
For this catlak repair to be productive, it should be made fresh before the catlag is over time.
At this point, there is another important situation, which is the length of the catlag. Although I tried it even though it was long, I did at least make it strong.
Seeing the cracks, don't say how you go like that. Because the cracks are long but they stay in the upper part of the glass, they do not cause any obstacle to the view. I did not change it because of the condition of the sensor not working when my glass was sensored. Actually we solved the sensor event, but I am not a complainant of this ...
Last summer, squares from the application to ten glasses ...
the cecol 2011-06-22 09:00:38
08.05.2020 15:38 # 8
So how do you go through the examination with this large glass crack?
08.05.2020 15:38 # 9
One evening, while replacing the wipers of my brother's car, the iron handle of the wiper hit the glass as a result of an incorrect bump and 3-4 branches were formed. At the time the maximum branch length was 10 cm. We said we would handle it in the morning and left. We came in the morning and we looked at the 10 cm branch that came to an end :) We changed the complete mosque.
08.05.2020 15:38 # 10
[QUOTE = badires]
I have undergone an imperfect examination with this catlag. There was no problem ...
08.05.2020 15:38 # 11
Carmania
The ingredients in the man's hand are very nice, the memory is a thin adhesive, and if you say why it is brushed, it goes into the catlak channel, I think it is thinner with alcohol, but I do not understand it, even though it poured alcohol, it is very good. thanks for sharing
08.05.2020 15:38 # 12
orhanax
Well, the man counted the materials one by one. Ingredients: Salt, pesticide, alcohol and water. I cannot believe that glass will be repaired with these. In my opinion, the disappearance of the crack in two hours and the brand of the pesticide does not matter.
08.05.2020 15:38 # 13
efsanemurat
there is a crack in the window of my car, I wonder if it works, if it works, it's really nice
08.05.2020 15:38 # 14
Asi Kaptan
Give it a try ..
08.05.2020 15:38 # 15
if anyone tries
would be great if he shares his impressions ....
08.05.2020 15:38 # 16
only_younus
salt does not dissolve in alcohol, I think this confirms nonsense
08.05.2020 15:38 # 17
AydinBeyol
I think they're kidding
08.05.2020 15:38 # 18
Kemanyak
I guess the gas that will emerge when pesticides, alcohol and salt combine is fatal. If there is a chemist friend, I would like to clarify me, but I would recommend that you consider that many compounds, especially poisonous gases, can come out of a mixture of a poisonous compound with alcohol.
08.05.2020 15:38 # 19
[QUOTE = pugti] change is something but the crack in the glass is not scratched, it seems to me, or am I wrong ?
I Do Not Believe In The Accuracy Share ...
the albaydemirc 2011-07-27 08:35:16
08.05.2020 15:38 # 20
[QUOTE = Kemanyak] I guess the gas that will emerge when pesticides, alcohol and salt combine is fatal. If there is a chemist friend, I would like to clarify me, but I would recommend that you consider that many compounds, especially poisonous gases, can come out of a mixture of a poisonous compound with alcohol. [/ QUOTE] You're so Right, Dude ... It is not known how healthy such an application is. The Last Curtain of Nonsense ....
Page : / 2
