Could you help
08.05.2020 16:44 # 1
batur_us
My vehicle is 2004 1.4xline 206 petrol. When I start the car, there is noise. When he shifts into 2nd gear and starts walking, he stops. what do you think could be a malfunction. the sound comes when the vehicle is idle and in 1st gear. When I press the clutch, it looks like it cuts off again. & nbsp; & nbsp; many thanks to the friends who helped ...
08.05.2020 16:44 # 2
Do you feel the vibration on your foot when you press the clutch pedal lightly?
08.05.2020 16:44 # 3
batur_us
No such a disturbing thing. When you press the light clutch, it cuts the sound and then comes again.
08.05.2020 16:44 # 4
batur_us
When I say that there is nothing disturbing, there is no problem about vibration.
08.05.2020 16:44 # 5
[QUOTE = batur_us] no such a disturbing thing. When you press the light clutch, it stops sounding again. [/ QUOTE]
Strongly possible malfunction caused by clutch ball. It is replaced with clutch kit. My questions are:
1. How many km and when was the last time your car was changed clutch set? Member 2. Is your clutch hard and does it go to the bottom easily when you press it? Member 3. Do you feel stiff at some point while pressing the clutch to the bottom?
koliva 2012-05-03 11:10:06
08.05.2020 16:44 # 6
cey cey
Could the belt be silent or not?
08.05.2020 16:44 # 7
batur_us
My 1st car is at 80,000 km. I bought the vehicle at 78,000. I do not know if the clutch set has changed
it can be comfortably pressed until the end of the 2nd.
08.05.2020 16:44 # 8
[QUOTE = batur_us] 1. my car is at 80,000 km. I bought the vehicle at 78,000. I do not know if the clutch set has changed or not
is comfortably pressed until the end of the 2nd. It seems like a little early on, but it depends on how it is used. Your answer to questions 2 and 3 has dissuaded me from my opinion a bit, but when you press lightly on the clutch, the muting of the voice still points to the clutch. Because of this, I thought that it was not a kayistan. Reviews
08.05.2020 16:44 # 9
impertore
I had a similar problem. as the gear changes & nbsp; or whirling noises while braking. said clutch ball scattered ..
