Could the vehicle's KM be reversed? Help
08.05.2020 18:56 # 1
Astra J
Friends, hello everyone. I am Mert, I am 25 years old living in Istanbul. I myself own the Astra J 1.4T vehicle. A few days ago we bought a second hand 2006 model 1.4 diesel 206 for a very close friend. The vehicle's interior and exterior condition was in good condition. When the friend went to see the vehicle, the ones who came before him came with his own masters and did not show the vehicle to the master by relying on their control knowledge. But when I got behind the wheel to try the car, I saw such a situation on the km indicator. As you can see in the video, at first, it seems to be 160.000 km, then when it makes half contact, it goes to 500.000 odd and then it gets back to its former form as you can see in the video. What is it? What is this, does anyone have any information?
Thanks in advance, guys.
http://www.youtube.com/watch?v=qafvwm-xx8s
08.05.2020 18:56 # 2
samet206
Now, my teacher, that is the km that comes out at first, you press the button on the indicator and it continues until I press the button again. If I aim to see the km done, I use it like this during the day or weekly. Obviously, I couldn't make a point of forgetting to reset the km counter and drop the km of the vehicle.
08.05.2020 18:56 # 3
KILIC
Sir, the first km should be the normal km, the last one should be the daily km, but there is an inconsistency here, obviously played. Under normal conditions, daily km reset itself at 1000 km. But there is an inconsistency here
08.05.2020 18:56 # 4
KILIC
[QUOTE = KILIÇ] Sir, the first mileage should be the remaining oil change, the last daily mileage should be, but there is a discrepancy here, obviously played obviously. Under normal conditions, daily km reset itself at 1000 km. However, there is an inconsistency here [/ QUOTE]
08.05.2020 18:56 # 5
herry
As if they made the dropping wrong, the vehicle is likely to give maintenance warning to 548,000 km, 10 thousand km afterwards. stand on the subject, thoroughly investigate before going back to the selling person, learn the exact truth of this event, if necessary go to the authority of the opel.
08.05.2020 18:56 # 6
Mesut48
The km remaining is the normal km after the first maintenance.
first counter goes back as soon as
I think the wrong number was probably entered, so an aphakia number came out.
My personal opinion is not playing, but the mileage was entered incorrectly, such as 575 thousand instead of 175 thousand.
08.05.2020 18:56 # 7
muro_60
70 thousand km per year has not done so much, you have to look at the worn condition of the vehicle.
08.05.2020 18:56 # 8
okaNStarss
I think it looks like they haven't assigned the software that is likely to be played km :)
08.05.2020 18:56 # 9
KILIC
[QUOTE = Mesut48] The km remaining for the first post maintenance is the normal km.
If I am not mistaken, teacher, the mileage was not increased to more than 20 thousand. He was resetting himself every 1000 km per day, there was obvious play per km or seven vehicles.
08.05.2020 18:56 # 10
pusutr
Stay away from this vehicle, I think.
08.05.2020 18:56 # 11
Astra J
Friends, this data corresponds to 70,000 km per year. Obviously, this is not possible for me, that is 70,000 km of roads per year. There may also be a mistake in the indicator, but I still could not unravel it.
Also, is there anyone who can explain what these 6 squares mean?
Thanks.
08.05.2020 18:56 # 12
muro_60
engine oil level. Didn't you make an inquiry
08.05.2020 18:56 # 13
Astra J
In the query we made from tramer, km information did not come. The friend who came before with his master came to trust him.
Where should the oil level be, I think there is a problem?
08.05.2020 18:56 # 14
pusutr
The oil level is in the form of oooooo, which shows the fullness. ooo___ also means _ the amount of fat deficiency. But I think the km has been reduced.
08.05.2020 18:56 # 15
Astra J
[QUOTE = pusutr] oil level is oooooo already, which shows fullness. ooo___ also means _ the amount of fat deficiency. But I think the km has been reduced.
then I am commenting that there is a problem in the indicator, because there was almost no oil in the vehicle and it was ooooooo on the indicator ...
08.05.2020 18:56 # 16
madblueblacksea
The first mileage is the distance left, but it should not be like that !! It counts down from 20000 and burns steadily ... the second level of oil .. 3. the normal km information. you have to press the button on the screen for daily mileage ...
I think all you have to do is to reset the mileage. reconsidered later
08.05.2020 18:56 # 17
Astra J
How do I reset the maintenance km of friends?
08.05.2020 18:56 # 18
serdaralisan
If my friend has been dropped, they say go ask about it.
08.05.2020 18:56 # 19
madblueblacksea
[QUOTE = Astra J] How do you reset friends care km? [/ QUOTE]
Turn the ignition on by pressing the button to the right of the indicator in the off position of the ignition and wait until the screen has finished counting down without releasing it. If the button shows 20000km after the count is over, the process is complete.
08.05.2020 18:56 # 20
Mesut48
[QUOTE = KILIÇ] [QUOTE = Mesut48] The remaining km to the first maintenance maintenance is the normal km.
My teacher writes 23 thousand remaining in my vehicle, so he can go forward Smile
Page : / 2
