Cost of having a 1.4 8v gasoline engine built
28.10.2023 12:00 # 1
ByYlmzZz
Hello, my car has started burning a lot of oil. It's at 300,000 km. I need to have an engine overhauled, but I don't know the cost. Has anyone had one done recently? What's the cost? Does a used engine make sense? Does anyone know a mechanic between Kocaeli and Tuzla?
30.10.2023 09:53 # 2
Hello, sir. Don't bother with a used engine; it's problematic because if you run out of oil, the valve stems and rubbers will loosen, and you'll need to rebuild the engine. It's more logical to build your own engine. Depending on the work involved, it'll probably cost between 30,000 and 40,000 lira. Two weeks ago, my father's Ford C-Max cost 19,500 lira just to have the cylinder head rebuilt.
30.10.2023 20:44 # 3
Berkay Erdinc
The price varies depending on the work done. It depends on where and how much the engine is worn and the brand of the parts you use. If you want to watch the 1.4 8v Peugeot engine, steering pump, transmission and electrical installation restoration I have done before, the link is below: https://youtu.be/caq33X3_TUw?si=6mj0_nZcFzLIM0sz
20.11.2023 13:33 # 4
ByYlmzZz
[QUOTE=sonerkyl]Hello sir. Don't get involved in a used engine, it can be problematic because if it runs out of oil, the valve stems etc. loosen, and then you have to rebuild the engine. It's more logical to have your own engine built. It'll probably cost 30-40 thousand depending on the work done. 2 weeks ago, just the cylinder head replacement on my father's Ford C-Max cost 19500 TL[/QUOTE] Does it cost 30-40 thousand TL? And how long will it take to finish this overhaul once the work starts? I thought it would cost around 20-25. Is there a well-known and good mechanic around Tuzla/Gebze? It's starting to get me down. I'm about to sell it and buy another car.
27.11.2023 15:03 # 5
ByYlmzZz
I am looking for a master to repair the torsion bar and undercarriage in the Tuzla and Gebze areas.
28.11.2023 08:46 # 6
[QUOTE=ByYlmzZz][QUOTE=sonerkyl]Hello sir. Don't get into a used engine, an old engine can have problems because if it runs out of oil, the valve stems etc. loosen and then you have to rebuild the engine. It's more logical to have your own engine built. It'll probably cost 30-40 thousand depending on the work done. 2 weeks ago, just the cylinder head on my father's Ford C-Max cost 19500 TL[/QUOTE] Does it cost 30-40 thousand? And how long will this overhaul take to be completed once the work starts? I thought it would cost around 20-25. Is there a well-known and good mechanic around Tuzla/Gebze? It's starting to get demoralizing, I'm about to sell it and buy another car.[/QUOTE] Unfortunately, they want around 10000 TL just for the labor, prices vary depending on the car. The last torsion repair cost was between 5000-6000 TL.
