Cooling water reduction problem
08.05.2020 20:04 # 1
OguzhanKucuk61
From time to time, my vehicle, which decreased in water, started to decrease a little more when we entered the winter. When I opened the bonnet one morning, there was no water in the tank. I added it and pulled it in. I added a lot of it. Then I looked at the state with the lid open. While circulating, I noticed that the radiator was dripping serially from the upper hose. I called the master, said easy job let's get it done. I went but we couldn't find the original piece. Master said he made up a hose from Tofaş. I said it would not be, but the hose is a hose. But when I asked the particle, he asked if it was diesel or gasoline. Doesn't it matter if it is diesel and gasoline? Would it be a problem if another hose was attached? The problem of water reduction has disappeared, but it is not very peaceful. oguzhankucuk61 2016-12-11 19:08:29
08.05.2020 20:04 # 2
EMRE_R19
I don't think anything will happen.
08.05.2020 20:04 # 3
OguzhanKucuk61
I think the hose wasn't zero, it was dusty. When I was looking for a piece, I was checking it wearing a master. But it was solid. I took his right and left and there was no hardness like that. But his feeling seemed a little more dull. Do you agree with you? You say the hose is a hose. If not, I will order the piece online if it has to be original. I don't know if I'm doing some meticulousness, but I'm not comfortable.
08.05.2020 20:04 # 4
samet206
It is better to wear the original, if there is an original, but if your job is seen, it will not be a problem until the problem arises again.
08.05.2020 20:04 # 5
EMRE_R19
[QUOTE = OguzhanKucuk61] I think the hose was not zero, it was dusty. When I was looking for a piece, I was checking it wearing a master. But it was solid. I took his right and left and there was no hardness like that. But his feeling seemed a little more dull. Do you agree with you? You say the hose is a hose. If not, I will order the piece online if it has to be original. I don't know if I'm doing some meticulousness, but I'm not comfortable. [/ QUOTE]
You are quite obsessed like me.
08.05.2020 20:04 # 6
OguzhanKucuk61
[QUOTE = EMRE_R19] [QUOTE = OguzhanKucuk61] I think the hose was not zero, it was dusty. When I was looking for a piece, I was checking it wearing a master. But it was solid. I took his right and left and there was no hardness like that. But his feeling seemed a little more dull. Do you agree with you? You say the hose is a hose. If not, I will order the piece online if it has to be original. I don't know if I'm doing some meticulousness, but I'm not comfortable. [/ QUOTE]
If the water does not decrease, I will do as you say. A Chinese proverb says: "Handling if it works" :))
08.05.2020 20:04 # 7
OguzhanKucuk61
[QUOTE = samet206] If the original is original, it is better to wear the original, but if your job has been seen, it will not be a problem until it causes problems again.
I realized the message now, teacher, thank you :)
