Control read failure
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
06.01.2023 12:55 # 1
Aga
I wrote the same topic in April 2022, but I am writing again because I did not get a suitable answer and the problem still persists.
I have a 2015 model 308 T9 car whose battery I changed in March 2022. Since April 2022, it opens the door from time to time with the remote control in my pocket, but does not open the side mirrors, when I want to go inside and start it, it gives "Fog Lights Failure" and sometimes it starts the engine and sometimes it does not. However, when you turn the Fog Lights on and off after starting, the Fault warning also disappears.
Now; The master from Peugeot Service changed the battery, so I think there is no other error caused by the battery change because when I took it for maintenance later, they said there was no problem. By the way, features such as start stop also work. After the problem, I changed the batteries of both remote controls, so there should be no battery problems.
When I take it to the related Service, when I take it to the related Service, when the "unit that reads the control" in the vehicle needs to be changed and it tells me when He said that they could not give a date because they did not know that he would come.
I would appreciate if anyone has encountered this issue before or has knowledge and can help.
