control problem in partner
08.05.2020 17:57 # 1
Driverghost
What I can do to make the control on the vehicle ignition switch disabled again, I would like to thank my friends who will help you.
08.05.2020 17:57 # 2
Serkan
1. Open the driver's door using the key
2. Keep the door open
3. Insert the key into the contact
4. Press the unlock button once.
5. Turn the ignition to the start position.
6. Press and hold the lock button for 10 seconds.
7. Release the button, turn off the ignition, remove the key.
8. Close the door (all doors must be closed)
9. Press the lock button 2 times.
10. If not according to this procedure, start and stop the vehicle. Do it again.
If there is no electrical fault in the switch, we should work with this method.
08.05.2020 17:57 # 3
Driverghost
Thank you for my help about the subject. I'll try this tonight. If there is a situation such as not being there, do I have another method to do?
08.05.2020 17:57 # 4
Partner2004
If it doesn't work with that method, there is a problem with the electric parts in the control.
