control battery short circuit solution
08.05.2020 17:36 # 1
thereal
Hello,
My car 2005 307 XS 3k 1.6 16v, I have a problem like this; I change the battery of the controller and it will run out after 2 days. I cleaned it with contact cleaner, I cleaned it with acetone, I did not remedy it, I replace the battery after 2 days, I tried it with different brand batteries. I took it to the keymaker and he showed it to an electronics shop, he said there is current on the board. Now there is a current, where can it be? Is there a way to detect this current, or will we have to make a new key?
08.05.2020 17:36 # 2
Burak
I think there is a current answer. How can it work if there is not enough current?
The topic has been moved to all questions about your vehicle.
08.05.2020 17:36 # 3
impact
I had the same problem, I deleted it, and it continued, and when I dropped it a few times, the control improved.
08.05.2020 17:36 # 4
Burak
[QUOTE = impact] I had the same problem, I deleted it again, it continued, and the control was fixed when I dropped it a few times .. [/ QUOTE]
"LOL" Classic Turkish solution applied hit two straighten "LOL"
08.05.2020 17:36 # 5
thereal
[QUOTE = Burak044] there is current answer, I think how will it work if there is not enough current?
All the questions about your subject have been moved to the section.
They said there is current in the sense that there is current, there is a short circuit in the current :) I asked if there is a way to detect this short circuit. div>
[QUOTE = impact] I had the same problem, I deleted it, and it continued again, when I dropped it a few times, it fixed the controller .. [/ QUOTE]
I now I don't knock the control off the floor: D, let's see if we're going to sacrifice another battery to try it.
