Continuous running parking sensor
08.05.2020 19:23 # 1
erenahmet95
After the friends had washed the car yesterday in the oil, the parking sensor always started to work in empty gear.
What could we have stopped?
08.05.2020 19:23 # 2
One of the sensors is short-circuited, but there may be a problem with the cable pulled for the sensor. They usually pull from the rear stops.
08.05.2020 19:23 # 3
erenahmet95
[QUOTE = sonerkyl] one of the transmitters is short-circuited, but there may be a problem with the cable pulled for the sensor.
Is my teacher under the bumper? Unfortunately I don't know the exact location :(
08.05.2020 19:23 # 4
most likely it is on the right or left side in the trunk under the floor
08.05.2020 19:23 # 5
erenahmet95
[QUOTE = sonerkyl] is probably in the trunk on the right or left side under the upholstery, my teacher [/ QUOTE]
Well, I looked at the place you said, there was something like a box, there were sockets.
08.05.2020 19:23 # 6
madblueblacksea
The parking sensor is normally receiving electricity from the reversing lights. Look at the reverse gear. If the sensor is constantly active, it should be on the back lamps
08.05.2020 19:23 # 7
Emask
My friend may have parked the sensors in the rear trunk right behind the plate and disassembled the brain, and he could have gotten the water inverted. If it took water, I hope it will not burn.
08.05.2020 19:23 # 8
erenahmet95
[QUOTE = Emask] My friend may have parked the sensors in the rear trunk right behind the license plate, disassembled the brain, and he could have gotten water inside the backside. If it got water, I hope it will not burn.
Let me look again tomorrow. Repair of this part is expensive, Hodja. I did not understand the vehicle did 20 thousand km in my brother, the problem did not come out, I bought it, now it causes different malfunctions so I use it very calmly :(
