CONTINUOUS LIGHTING AIRBAG LIGHT
08.05.2020 20:33 # 1
LUXUS
Hello pevgeot family: I bought a 307 2 months ago, when I bought it, the airbag light was always on like a malfunction notification. There is no place I did not take, everyone says something different. Let's change the whole thing in the service.
08.05.2020 20:33 # 2
Hello, welcome to us first. The problem is in the headlight signal arm, which gives the error code when my teacher is connected to the vehicle. I think change the headlamp signal arm first
08.05.2020 20:33 # 3
LUXUS
Tskler for cvp. It was said that it was problematic. I was wondering if the change was around thousands TL. Orj.
08.05.2020 20:33 # 4
[QUOTE = LUXUS] Tskler for cvp.It was the one who said it was a problem.I thought it was a problem.
you need to find a good auto electronics engineer, repairing. this may have caused problems. or something like oxidation.
08.05.2020 20:33 # 5
LUXUS
08.05.2020 20:33 # 6
pusutr
In the meantime, please let us use our beautiful Turkish properly.
08.05.2020 20:33 # 7
LUXUS
Hodja, there are forms of discussion about literature, you can join the discussion platforms more comfortably ...
08.05.2020 20:33 # 8
sosyolog_56
mrblar teacher. I just bought my 307 vehicle. the seat belt and airbag always gave fault. I took it to an auto electrician. I think the sockets under the seats have oxidized. cables etc. The change was eliminated at a total cost of 30 TL. Thank God there is no problem right now. If you want to show me a electrician first.
08.05.2020 20:33 # 9
Orcun.Dmr
My 307 is going out for 1 month, it is on for 1 month, the armpit sockets are clean. I think there is a problem with the com2000 because the headlights are blinking recently when the ignition is switched on.
08.05.2020 20:33 # 10
[QUOTE = Orçun.Dmr] In my 307, 1 month is extinguished, 1 month is constantly burning, armpit sockets are clean. I think there is a problem with the com2000 because the headlights are blinking recently when the ignition is switched on. [/ QUOTE]
then your problem is com2000 brother. min 200 tl max. As if there is 700 TL cost
08.05.2020 20:33 # 11
Orcun.Dmr
[QUOTE = sonerkyl] [QUOTE = Orçun.Dmr] My 307 goes out for 1 month, 1 month is constantly on, the underarm sockets are clean. I think there is a problem with the com2000 because the headlights are blinking recently when the ignition is switched on. [/ QUOTE]
Exactly Soner brother com2000 is out of order. I'll change it when it's time to go where it goes. LOL
08.05.2020 20:33 # 12
eyupsenturk
Hello everyone my name is Eyüp 2004 I have 1.6 xt 307 vehicle and I live in Edremit. I have a similar situation like this,
When I drive on the road in my car, it stops signaling after a while, I turn on the headlights, turn on the horns after the headlights turn on, the horn does not work at that moment. then I touch the signal arm, it gets better. rather, it was improving. Then I took it to an electrician. He intervention . After the intervention, my signal arm has become harder now. The problem continues, though not as much as before. Also, the air bag light turns on as soon as you start the car. esp hjata is burning after the vehicle moves a bit.
What kind of a path should I take? what could be the main source of the problem?
frankly there is a special service called edremit engin service but i am not convinced. Who can solve this problem in Izmir? or is there anyone who knows he knows in Balıkesir?
08.05.2020 20:33 # 13
[QUOTE = eyupsenturk] hello everyone my name is Eyüp 2004 1.6 xt 307 vehicle I live in Edremit. I have a similar situation like this,
Hodja, welcome to us first. Unfortunately, you have no choice but to change the headlamp signal lever.
