CONTACT is broken
08.05.2020 17:37 # 1
rhcpeppers
I sent the car to Mehmet Usta with a friend and stopped the car on the road, and then found the way to Kaka Garajturkun. said the contact is scattered, said, said, the master, 450 lira, will change. doesn't it repair? Isn't there anything to come out? How do we handle this work, shouldn't it be necessary to have a repair? off offf
08.05.2020 17:37 # 2
ahmetismet
How is that happening? I really heard it for the first time ...
08.05.2020 17:37 # 3
rhcpeppers
Thanks guys, I had a problem with the clutch of the car, it was done before. Again, it caused problems.
the car was not working
08.05.2020 17:37 # 4
samet206
It is not clear what will happen when it is too past.
08.05.2020 17:37 # 5
sezar206
You have two ways, brother. You will put a button somewhere on the edge, just turn on the lights and then start with that button. There are those who use it. Secondly, I think you can buy and install a reno contact. Most likely, you will cancel the immo and use it normally. These spoil the original a little, but :( 450 was too much money.
08.05.2020 17:37 # 6
sezar206
There is always a question for the issue, but you need to change the door locks, otherwise there will be two keys.
08.05.2020 17:37 # 7
Bunyamin.Kar
Do some research, my friend, for example, do not go out, the starter level of my contact is broken, the starter is pressing but not throwing back, but I am traveling like this now :)
08.05.2020 17:37 # 8
bysarsinti
If you can send it with my brother or take a photo, send it to me and I will help you. I repaired the ignition of many cars. the contact is collected if dispersed. no need to change it.
08.05.2020 17:37 # 9
rhcpeppers
Thanks guys, really a lot of money 450 pounds. There must be a way to do this, I don't want it, but I said to a friend, find it, look at someone. I looked at the internet to see if I could find it, but I could not find it, what did I send the car to?
08.05.2020 17:37 # 10
rhcpeppers
I am waiting for help from Istanbul :)
08.05.2020 17:37 # 11
Barut
The same thing happened to me, I made 40 to a solid keymaker.
08.05.2020 17:37 # 12
rhcpeppers
if we find it
08.05.2020 17:37 # 13
elsoberano
307 of a friend from the workplace broke down, they made it for 60 tl.
08.05.2020 17:37 # 14
bysarsinti
Başak mah in Istanbul . Yeşilvadi cd.
Baş Çarşı shopping center Stage 5
no: 11 - 5A Başakşehir / İstanbul
Tel: (0543) 592 42 64
(0535) 673 69 67
We are at your service 7 x 24.
Our branch.
Yuzyil mah. barboros cad.
61. Sok. no: 3-A
Bağcılar / İstanbul
Tel: (0212) 432 35 60
(0535) 673 69 67 (ahmet master)
(0543) 592 42 64 (ali master)
I bought Ali master from Arazmir, Selcuk from Shaban Bey and my brother will help.
08.05.2020 17:37 # 15
ismailkaya
I am in contact with you.
08.05.2020 17:37 # 16
rhcpeppers
Thank you, but the car is on the umbrellas. Is there not a competent person doing this job?
08.05.2020 17:37 # 17
rhcpeppers
friends, this job needs to be resolved tomorrow. the market will not be anyway. If we could not do it anymore, if we change the contact, we will both be left without a car and have paid the world.
08.05.2020 17:37 # 18
rhcpeppers
Guys, isn't it a detachable thing? If it is dismantled, I will have it removed tomorrow, then I will send it to the keymaker who will understand the lockman, and I will have a car for 1 week.
08.05.2020 17:37 # 19
Bunyamin.Kar
the contact is being dismantled, but it is a bit laborious to say from me
08.05.2020 17:37 # 20
rhcpeppers
auto electrician or something will be removed
Page : / 2
