Consultancy on LPG Consumption
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:10 # 1
Akif Burak
1998 I have a Model 406 SV. About a year ago, I had my Atiker brand tube attached to my vehicle. While there was no problem with consumption, he started to burn 51 cents per km in the future. My fuel consumption (at LPG) has now dropped to 32 cents. I would appreciate if I have friends who are intermediaries in this case, if they inform me about fuel consumption (for comparison) ...
08.05.2020 15:10 # 2
[QUOTE = Akif Burak] 1998 I have a Model 406 SV. About a year ago, I had my Atiker brand tube attached to my vehicle. While there was no problem with consumption, he started to burn 51 cents per km in the future. My fuel consumption (at LPG) has now dropped to 32 cents. I would appreciate if I have friends who are intermediaries in this case, if they inform me about fuel consumption (for comparison) ... [/ QUOTE]
Is your vehicle automatic ????
The fuels of the 2.0 16V engines with xu10j4 code in your vehicle are not very economical. In the past, one of our friends was saying that the same vehicle had an automatic and that it could not drop the fuel. Waste is attached on it. already can't get on gas. The settings of the vehicle do not light up properly. The other is fine. there is not much to do ...
but I can say check the software update. ecu software of the vehicle may not be updated. I advise you to find and look for a service that understands the software update. It can provide benefits in an amount. Of course, after this update, a small gas adjustment may be required.
It may be necessary to have a transmission control in one. Because if there is a loss of power in the transmission, this will be reflected as extra fuel.
08.05.2020 15:10 # 3
Akif Burak
[QUOTE = cecoli] [QUOTE = Akif Burak] 1998 I have a Model 406 SV. About a year ago, I had my Atiker brand tube attached to my vehicle. While there was no problem with consumption, he started to burn 51 cents per km in the future. My fuel consumption (at LPG) has now dropped to 32 cents. I would appreciate if I have friends who are intermediaries in this case, if they inform me about fuel consumption (for comparison) ... [/ QUOTE]
First of all thank you for your interest. My car is manual, not automatic. There is no problem with its traction, it does not light up in my fault light. I did it at a cost of 1500 pounds a week ago. Software update was made in the 1st industry in Izmir, no problem was seen, even the engine was said to be very clean, apart from that, it was 15 days after the clutch was made, the tool changed. I think it's because the engine is big and the D segment is a car. There are those who burn 27 cents out of their peers, but I think it should be related to using a revolution.
08.05.2020 15:10 # 4
In general, if the vehicle is well maintained, if the software is up to date, if you are driving in a very slow way, it is very normal for this car ... the most important factor affecting the fuel is the usage conditions of the vehicle. short distance ticking, traffic density, sudden departures, rapid acceleration, etc. change the event very much. At the same time, fuel quality is effective. Have you tried to buy fuel from different places?
08.05.2020 15:10 # 5
Akif Burak
I have measured the fuel in several places by filling the tank at various times, but the result is the same. Actually, the main source of the problem is gasoline prices :) .. Thank you again for your attention ...
08.05.2020 15:10 # 6
Bedo4life
My brother, I am thinking of getting LPG, but I am in the research stage.
08.05.2020 15:10 # 7
Akif Burak
[QUOTE = Bedo4life] my brother, I am thinking of getting lpg, but I am in the research phase, I hope I will get it next week but I do not have a definite brand in my mind, so now you are not satisfied with the atiker? [/ QUOTE]
I am not satisfied from the Atiker brand tube, my injectors are currently Zavolli, but the system is still Atiker.
08.05.2020 15:10 # 8
share it with us when we make the system complete zavoli, will we solve it? I wondered as well. I had done at least 5-6 d80 406 maintenance before, all of them were working properly. There were many fuel consumption complaints in one of them. lambda defective output etc. lde one lpg ecu is important in software. In addition, the waste model on the top of the vehicle is important in this regard. Maybe a part in the system may be incorrect in the map or regulator ...
08.05.2020 15:10 # 9
hunterakon
All I know is that my vehicle burns 16krş in LPG: D burns between 25-30KR in gasoline, I am so relieved to have lpg installed, I think that there is neither traction nor excessive burning in the vehicle.
08.05.2020 15:10 # 10
Akif Burak
Sec. Hunterako's,
If your vehicle is 406 like my vehicle and 16 krş. If it burns, I call it supernatural. We had conversations with a lot of 406 users.
Sec. Cecol of
Apart from the dealer where I had the tube installed, I showed the vehicle in different services, but they stated that there was no problem in the software or the tube related situations.
08.05.2020 15:10 # 11
[QUOTE = Akif Burak] Sn. Hunterako's,
Sec. Cecol of
that friend's car is zero km 206+ they will not compare your car's fuel :))
there are small machines, new and light, mountains, by the way :))
You can reach me when you cross the road in his awe. See you, I hope ..
08.05.2020 15:10 # 12
Akif Burak
[QUOTE = cecoli] [QUOTE = Akif Burak] Sn. Hunterako's,
Sec. Cecol of
I hope I will disturb you, I will wait for Izmir, if you fall in your way ...
08.05.2020 15:10 # 13
I hope my path will fall to summer. :))
