console painting
08.05.2020 19:01 # 1
monalos
Hello friends, I am aware that I opened a lot of topics in the forum.
The current problem is how to get the color in the water. It is called piano black. It will cost me a lot.
08.05.2020 19:01 # 2
206quik09
I know they do it with foil do you want to do it yourself
08.05.2020 19:01 # 3
monalos
we take it to the bio that makes it matter
08.05.2020 19:01 # 4
Barut
Glossy black spray paint works. If you intend to do it yourself, I can give detailed information. Or if you do it in the painters, it is enough for them to say bright black, they will not understand if you said piano black.
08.05.2020 19:01 # 5
sezar206
In fact, if I get involved, it would be if we made the door handles ventilation and that piece in the consul gray.
08.05.2020 19:01 # 6
samet206
If you are going to disassemble the console, first of all, you will use piano black foils in the places where you are filming. It is most likely that you do not have to ask the dead end because it is troublesome. If you apply a black pearl paint to the tube or you can use bright black spray paints that are sold in normal construction markets.You can apply a varnish every 3-4 times in half an hour. Opposite, unscrew the paint, any painters can handle the painting process in a simple way, but I can't stop filmmakers dealing with foil.
samet206 2015-01-18 23:18:19
08.05.2020 19:01 # 7
Adem Kurtuldu
First of all, I don't touch the bumpers and the bands, I asked a few people who applied it to their vehicle and they said that it was exfoliating after a while.
08.05.2020 19:01 # 8
samet206
[QUOTE = a.kurt] First, don't touch the bumpers and bands, I asked a few people who applied it to their vehicle and they said it was exfoliating after a while [/ QUOTE]
My teacher stems from the workmanship, while applying the paint pouring process, if he throws the plastic liner underneath and throws at least two coats of paint and varnish on top, it will not be easy to paint. In matte black paint, there is no escape to peel from the sun, so they will surely get old. It is very hard to keep the plastic parts new, no matter what is applied.
08.05.2020 19:01 # 9
muro_60
you come with me
http://www.sahibinden.com/ilan/vasita-otomobil-peugeot-otomatik-temiz-bakimli-206-188746573/detay
the owner of this vehicle makes my neighbor water veneer foil do whatever you want
08.05.2020 19:01 # 10
monalos
[QUOTE = muro_60] you get me next
bro, I'm in izmit, you are in my mind. When I return to the buckle, I will come to you.
Brother Bidet kalarifer is not much in the honeycomb, but there is a water leak. Is there any place we can do there? gasket replacement or complete radiator? + Is it possible to remove the breast removal while removing the honeycomb?
monalos 2015-01-19 11:51:21
08.05.2020 19:01 # 11
monalos
[TUBE] xe_h8tvdwqk [/ TUBE]
You should pay attention to 5:07 minutes in the video, what filter he has removed has every 206?
monalos 2015-01-19 11:48:29
08.05.2020 19:01 # 12
muro_60
[QUOTE = monalos] [QUOTE = muro_60] I will make you come to me
[/ QUOTE] We have it built according to the situation, we look at my 307's routine, I tightened the bolts in the forest, cut it out
08.05.2020 19:01 # 13
muro_60
Whether or not the pollen filter is in the air
08.05.2020 19:01 # 14
samet206
Exactly the pollen filter is available in all 206's.
