Console Frames Painting
08.05.2020 20:52 # 1
conteo
Hello friends, today I have sanded the paint on the front console of my 207 Comfort single-door car, because it discolours and I am thinking of spray painting.
"border =" ">
only the upper part of this place with Motip Universal Black Alkrik spray paint
"border =" ">
I would like to paint these parts with an alkyd silver spray paint. Apart from this, there is a need for varnish or primer spray paints.
conteo 2018-05-06 19:01:51
08.05.2020 20:52 # 2
My brother, first of all, if you want a long lasting and clean job, use plastic primer and both paint will be smoother and cleaner. If there is no matt varnish or paint, it will be deformed in a short time.
08.05.2020 20:52 # 3
maximusti
I didn't use primer but I used matte varnish,
the slightest did not deform, I painted the front frames and the frames of the door handles.
Before painting, I would rub scotch bright's hard part thoroughly and remove its gloss to hold the paint.
08.05.2020 20:52 # 4
conteo
I understood, I was going to buy metallic paint, then I would like to buy vasgeciorum matte paint and primer and start the process.
08.05.2020 20:52 # 5
conteo
Hello friends, sandpaper paint was very nice, but the idurts that I applied to the top did not hold the good light, and the 50sl material I took was rubbish. not. I will put the picture when the coatings are finished
08.05.2020 20:52 # 6
RP393
Those who can not find primer paint or say that there is no extra cost, can make a fine thin coat of paint, draw 2000 watery sandpaper and switch to topcoat paint. Also, don't be surprised by the polish in the paint. It paints homogeneously while painting, flowing etc. I can not.
08.05.2020 20:52 # 7
conteo
In this way, it is only my attitude for friends who will try to work. I am pleased with the result that I took my job in 2 hours with this advertising tape and a blow dryer that I bought only 10tly. Smile
"border =" ">
"border =" ">
08.05.2020 20:52 # 8
I think the subject of paint requires some experience. foil is good for your hands Clap
08.05.2020 20:52 # 9
KILIC
The foil is more beautiful, but the room can be torn in a small rub.
08.05.2020 20:52 # 10
conteo
Thank you Sonerkyl Smile Exactly, there is a tearing of the foil. Sleepy
