Connecting the old power supply to the car?
08.05.2020 18:49 # 1
ahmet_bjk
Hello friends...
I have a 1000W power supply with a faulty battery. I plan to pull the cable from the cigarette lighter and combine it with the battery connection cables of the power supply and get 220 VOLT electricity from the vehicle.
1) Do you think the vehicle would have a drawback?
Thank you...
08.05.2020 18:49 # 2
evilss
Hello my friend it will vary depending on the load you have attached. If you are going to connect something like TV style laptop style, it will not be a problem. If you pull the battery directly from the battery with a power cable, you will reduce the risk a little bit.
evilss 2014-10-08 20:36:13
08.05.2020 18:49 # 3
Alicilik
When the vehicle is equipped with a cutout fuse, when you install a tool that requires high current, the supply fuse fuses, depending on the supply coker situation. Finally, cakmak fuses the insurance.
Why are you doing it? I bought an adapter to reach 50tl, I use 150w catir catir. You can draw up to 12 amperes of the fuse of the cakmak fuse.
