Connecting circuit to RB3 tape output?
08.05.2020 17:03 # 1
ahmetismet
Mrb friends, I have a 307im 2004 model with rb3 cassette player.
My electronics is good and I made a sound sensitive light (stereo) circuit. The circuit works when I connect it to the computer. . There are 2 modes in the circuit, there is a brightness setting, one of the modes lights the leds continuously, in the other mode, it lights up according to the intensity of the sound that the tape receives from the left and right channels. I put the circuit in the splitter box I didn't use and put it in the torpedo. In the scheme of the circuit, the inputs of my circuit are also in the form of L, R and GND, while I mounted the circuit in the car now, I connected + FL to Lye, + FR to Rye, but I hesitated to combine -FR and -FL. Would it be a problem if I connect this shape? or will there be sizzling in the sound? And if it is wrong, how should I connect the above?
When I connect and run the circuit, I will share it with the video.
Thanks ...
08.05.2020 17:03 # 2
Alicilik
I did a similar work to yours.
I would like to get detailed information about what kind of circuit you have established. So I did it with the tip31 capacitor trigger. I made two stereos, but I haven't tried the minus thing obviously.
I used the RCA amplifier outputs in my tape (pioneer). It was suitable for tip31.
If your problem is out of my experience, I can give an example. The back outlets of my original tape were closed. I connected one of the loudspeaker cables + end pre-outs I pulled to the other one to the rear outlets. Maybe it will help.
If it is not worth risking, it is not a problem to pull one more cable.
08.05.2020 17:03 # 3
Alicilik
This mono made. I also did the wired remote. I plan to do this process in your trunk. Let me be as clear as my voice in fairs and festivals "Wink"
[TUBE ] 3nwfwtouqqg [/ TUBE] Reviews
08.05.2020 17:03 # 4
ahmetismet
I couldn't concentrate on it because I made the installation late. I used tip31, I made 2 gnds by combining 2 right and left emitters. newline ">
now I need to find a solution to get the sound and light at the same time, do you have any idea?
this is the circuit diagram:
Reviews
Reviews
08.05.2020 17:03 # 5
Alicilik
As you said, I did not have the opportunity to try the sound event. The cable crowd on the back of the tape and the settings are reset every time I disassemble, I am lazy to disassemble. There is no other tape, I can try.
I will take 2 3.5 inputs from one piece and try mp3 player. I'll connect a dimmer speaker to a dimmer light circuit. Let's see how.
How is your enlightenment? If you look at the video, if I raise the sound too much, it triggers, maybe the RCA output is low (max. 4v) could it be due to it?
