Connect 206 dvd player
08.05.2020 16:20 # 1
wldnsxc
Friends have a nice holiday & nbsp;
NAVITECH CDT-6800UDT I bought a tape myself I want to connect the car 206 gti how to connect plus minus chassis which ones pictures can you help?
/ div>
yellow battery plus & nbsp;
black ground
red ignition switch
orange reverse gear < / div> says
[/ URL]
[/ URL]
[/ URL]
08.05.2020 16:20 # 2
Each radio is connected to the yellow and red (+) end of the connection, the black one is (-). The speaker cables are made as 2 wires of color separately. But one of the cables has a black line. easy, don't bind the car's (+) and (-) ends to the output.
08.05.2020 16:20 # 3
The red wire (+) tip that comes in your car is already (-) in the wrapped green one.
08.05.2020 16:20 # 4
wldnsxc
do not connect the (+) and (-) ends of the car to the output. I can not understand this part. I understand that by combining the yellow and red, I will connect the black to the minus, so the orange back v in the tape wiring diagram, where do I connect what you call tes?
08.05.2020 16:20 # 5
If you have a video cable for that reversing camera, you have it connected to that camera.
08.05.2020 16:20 # 6
wldnsxc
do not connect the (+) and (-) ends of the car to the output. I couldn't understand this part, you wanted me to give it directly from the battery
< span style = "text-align: left;: rgb251, 251, 253;"> there is also a brown tip handbrake says it will bind my chassis
wldnsxc 2011-11-06 22:30:29
08.05.2020 16:20 # 7
no no no direct connection from the battery, no problem. I wanted to connect the plus and minus poles of the battery to the speaker outputs. Some friends accidentally burn the room speaker outputs.
08.05.2020 16:20 # 8
wldnsxc
ilhan :) no, or i studied electronics for 6 years, i shame bro & nbsp;
08.05.2020 16:20 # 9
that brown color is connected to the hand brake for warning. Then the hand brake is pulling the cable from the client and connected to that end.If the hand brake is pulled, the tape will warn you. stops & nbsp; "Star"
< / div>
