Computerized screen compatibility with 301 active model
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:50 # 1
ottoman58
Hello, my car is 2013 model 301 1.2 active model. I would like to remove the original confirmation and replace it with the screened blutoot tape on allure hardware. Does it adapt directly
08.05.2020 20:50 # 2
First of all, welcome to us. I do not think my teacher will be in trouble. I remember that our subscriber of @alicilik had applied it to 301 vehicles.
08.05.2020 20:50 # 3
ottoman58
Thank you. Thank you. Our meeting with peogeot was 301. :)
it requires additional wiring in several places, etc. so I was hesitant, is there an electrical connection for the display, or does the gas gauge blutot work in full harmony?
08.05.2020 20:50 # 4
@Alicilik If you send a special message to our friend, my teacher will give you the necessary information.
08.05.2020 20:50 # 5
ottoman58
Ok, thanks a lot.
08.05.2020 20:50 # 6
Alicilik
RDE - RD45 replacement
RDE (single-line self-screening tapes.) Some hardware. The tape's information comes out of the screen in the middle of the tape. There are 2 models of this.
Level1 There is only mp3 cd aux radio feature. 123456 keys at the bottom of the screen
It has Level2 Bluetooth usb aux mp3cd feature. 123 and 456 keys are on the side of the screen
In the RD45 system in Allure packages, there is no screen in tape. The screen communication is on a separate screen with the trip computer.
To make this change,
Rd45 tape
efmc uds screen
Display socket
Screen and tape compatible frame
Microphone and installation
USB aux apparatus and installation
You must obtain the display socket and connect it to the vehicle in your vehicle, while there will be no display socket when connecting them. Afterwards, the location of 2 terminals in the main socket coming to the tape will change and the installation will be completed.
Then a few activations will be connected to the computer. If activation is not done
_ Your serial number will be encoded to the tape, otherwise you will hear a beep continuously.
_Displays do not appear on the screen
If you think I have a friend, I can help.
08.05.2020 20:50 # 7
ottoman58
I do not have it right now, but I found it in a few friends, the original screen and tape in their vehicles were standing because they had double screen.
however, as you have told, these devices will not be sufficient alone, additional things will be required for additional connection :(
08.05.2020 20:50 # 8
Alicilik
The system consists of the following parts
rd45 tape headunit
efc c uds screen
Compatible frame
USB aux port and fitting
Microphone and its installation
As I said, the screen has no socket, you have to add it. It's not a difficult process. You get attachments from 4 cables coming to the tape
Finally, by connecting to the device in an authorized or special service, the chassis number of the tape will change and a few parameters related to the screen will be activated.
08.05.2020 20:50 # 9
ottoman58
Thank you very much for your help, how can we get from the sets in your friends.
08.05.2020 20:50 # 10
erhandemetgul
Hello, Which of the 4 cables that come to the tape are getting attachments. can you take a picture? And which two pins are we replacing? I would be glad if you could help.
27.12.2021 17:34 # 11
Mehmet cinpolat
You said 10 in the place where you slm, which
is that
27.12.2021 17:35 # 12
Mehmet cinpolat
RDE - RD45 changeover
RDE (single line self-screen tapes.) Happens on some hardware. The information of the tape comes out from the screen in the middle of the tape. It has 2 models.
Level1 It has only mp3 cd aux radio feature. 123456 keys are at the bottom of the screen
Level2 Bluetooth usb aux mp3cd feature. Keys 123 and 456 are on the side of the screen.
Rd45 tape
efmc uds screen
Screen socket
Frame compatible with screen and tape
USB aux apparatus and its installation is required
there will not be a screen socket when connecting them, you need to supply the screen socket in your vehicle and connect it to the vehicle. Afterwards, the location of 2 terminals will be changed in the main socket that comes to the tape, and the installation will be completed
A few activations will be made by connecting to the computer at the end. If activation is not done, your
_ chassis number will be coded to the tape, otherwise you will hear a continuous beep.
_Warnings do not appear on the screen
If you think about it, my friend has a set, I can help.
27.12.2021 17:36 # 13
Mehmet cinpolat
There is no number 10 in the Slm socket, but it gives information about which one. isini
22.11.2022 23:18 # 14
Orhan o
Hello, my teacher has a 301 active package, I want to install a tape recorder with an information screen, but the tape cables in my vehicle do not support it, if there is any apparatus for this, where can I get it, thank you, I wish you a good work.
24.12.2023 02:43 # 15
BySavash
[QUOTE=Reception]RDE - RD45 conversion: RDE (single line self-display tapes) is available on some hardware. Tape information is displayed on the screen in the middle of the tape. There are 2 models of this. Level 1: It only has mp3 cd aux radio feature. The 123456 keys are under the screen. Level 2: It has Bluetooth usb aux mp3 cd feature. The 123 and 456 keys are also on the side of the screen. In the RD45 system in the Allure packages, there is no screen on the tape, the screen communication is on a separate screen with the trip computer. To make this change, you'll need an RD45 tape recorder, an EFMC UDS screen, a screen socket, a frame compatible with the screen and tape recorder, a microphone and its installation, and a USB auxiliary device and its installation. If there isn't a screen socket, you'll need to obtain the screen socket in your vehicle and connect it to the vehicle. Then, swap the two terminals on the main socket that connects to the tape recorder, and the installation is complete. Finally, connect to the computer and perform a few activations. If this isn't activated, your chassis number will be encoded into the tape recorder, otherwise you'll hear a constant beep. No warnings will appear on the screen. If you're interested, I have a friend who has a set; I can help. [/QUOTE] Hello, which two terminals are we swapping in the socket you mentioned? A reply would be greatly appreciated, thank you.
