Compression Test How is it done? ( Illustrations
08.05.2020 14:06 # 1
elenor
Tool used: Compression tester, This picture has shrunk for forum layout. Click here for the original size. First, we remove our ignition wires, and open the fuse panel and remove our 15A fuse (this fuse injector fuse). This picture has shrunk for the forum layout. Click here for the original size. This picture has shrunk for the forum layout. Click here for the original size. Then we remove our spark plugs. We can make a short check here, if you take our spark plugs out and examine them, you should understand that if you are closer to white, you are in the rich mixture, if the color is more black, then you are rich. This picture has shrunk for the forum layout. Click here for the original size. This picture has shrunk for the forum layout. Click here for the original size. Before using the compression tester, the instrument should be checked and not damaged.These are important for our test to give a healthy result.Then we place our instrument on the first cylinder.We insert the tool as normal as the spark plug enters. While one person is holding the test device, another person should press the gas pedal to the end. We press the pedal while the pedal is pressed to the end. This picture has shrunk for the forum layout. Click here for the original size. This picture has shrunk for the forum layout. Click here for the original size. We are reading our test device, if you think there is a confusion in your device, carefully perform the operations by resetting the compression tester one by one in 4 cylinders. The low compression engine we saw above came out between 175-185 psi. has shrunk for the order. Click here for the original size. This picture has shrunk for the forum layout. Click here for the original size. We repeat the procedures I explained above in the same way and start our test. Our first cylinder is 250 psi! This picture has shrunk for the forum layout. Click here for the original size. This picture has shrunk for the forum layout. Click here for the original size. Our second roller is 250 psi again, our third roller is 255 psi! This picture has shrunk for the forum layout. Click here for the original size. Finally, our 4th cylinder is 250 psi. It is a good result. After completing the test, our fuse plugs should be installed carefully, and if the spark plugs appear problems, it should be replaced. ALINTIDIR.
08.05.2020 14:06 # 2
Onur
nice sharing
08.05.2020 14:06 # 3
Onur
How is it done in automatic transmission vehicles? full throttle or engine?
08.05.2020 14:06 # 4
tugrabozan
In the past, when we were going down the ramp, we would see if the gears were downshifting, and now I don't know how good or bad everywhere, but I do not know my father's traditions.
08.05.2020 14:06 # 5
haruncoskun
[QUOTE = horby37] How is it done in automatic transmission vehicles? full throttle or engine? [/ QUOTE]
08.05.2020 14:06 # 6
Kifanhom
Nice share
You have to make it every 20k km
08.05.2020 14:06 # 7
ErkanKurnaz
very informative, good health
08.05.2020 14:06 # 8
BurcUMUL
Nice sharing thank you. It seems like the fastest and most satisfactory test that can be done when buying a second hand car. Especially in high compression cars.
08.05.2020 14:06 # 9
badcombatant
I saw the beautiful sharing applied for the first time
08.05.2020 14:06 # 10
shamed
Nice share
08.05.2020 14:06 # 11
vbmaster
I really see it for the first time :)
