Component selection
08.05.2020 17:44 # 1
Texas16
http://www.hepsiburada.com/liste/harward-hr-6205-component-system-hoparlorler/productdetails.aspx?productıd=otreishr6205&categoryıd=26090&navq=fh_eds%3d%25c3%259f%26categoryid%3d26090%26fh_view_size%3d12% 26fh_start_index% 3d72% 26fh_sort_by% 3d-order_stock_attribute_pl% 252C-ranking_cocktail_bestsel are 26fh_secondid%% 3dotreishr6205 26fh_lister_pos%% 3d80% 26fh_locatio% of 3d 252F%% 252fcatalog01 252ftr_t% 252fcategories%% 253C% 257bcatalog01_60002705% 257D% 252fcategories% 253C% 257bcatalog01_60002705_2147483631% 257D% 252fcategories% 257bcatalog01_60002705_2147483631_253575% 257D% 253C% 253C% 252fcategories 257bcatalog01_60002705_2147483631_253575_26090%%% 257D% 26fh_refview # visuals are 3dlist
which do you think is for peugeot 307 ???
08.05.2020 17:44 # 2
qqyyxx
My brother is talking about every occasion when the issue is urgent. There is not enough volume to handle the speaker. Don't waste your money, keep the original twitter and woofer strengthening. An oval may also be considered in the posterior sponge, even if it does not have an image.
08.05.2020 17:44 # 3
Texas16
[QUOTE = 307bursa] both will be in front of them
for the back you need to find 13 cm of them
Do you have any amphitheater and you can't feed them :)
There is full installation, I am unstable in mid-afternoon.
08.05.2020 17:44 # 4
Texas16
[QUOTE = qqyyxx] my brother is urgent whenever the subject is urgent at every opportunity, 307s have such a damn loud speaker, whatever you put in, you cannot get a sound. There is not enough volume to handle the speaker. Don't waste your money, keep the original twitter and woofer strengthening. An oval may also be considered in the posterior sponge, even if there is no hos image. [/ QUOTE]
When you connect the original columns to the amphitheater, they give a sweet sound.
08.05.2020 17:44 # 5
Alicilik
165mm is suitable for the front, but you can also use 160 and 170mm.
Whatever you put friends in the volume, he says no matter, but with the infinity 6530, I saw a stroke of stroke. You can also make a frame on the back with the same shape and use a 160 or 165mm speaker. There are those who do.
I prefer JBL, but make sure it's original.
