Compatible with PIONEER TS-W 308 D4 1400W amplifier?
08.05.2020 17:59 # 1
onuuuurrr
slm friends have in my hand the moment amp;
and devices connected to this amplifier
1 pair ts-20 old version
1pc jbl cs1214 1000w 30cm
AMFI BRAND MODEL FEATURE:
BOSCHMANN JA-948ATX 1600w Angry
4/3/2 Channel PWM Power MOSFET
Highly Refined Regulated PWM Power Supply
On-Board ST (TM) PWM Power Supply
Continuously var iable Active Crossovers
2-piece Chromed Stainless Stell Aluminum Cast Heat Sink
Isolated Task Specific Power Stages
4 ohms RMS Output: 100Wx4 CH RMS = 400W RMS
2 ohms Cont.Power Output: 200Wx4 CH RMS = 800W RMS
4 ohms Bridged Power.Output: 800Wx2 CH = 1600W RMS
4 ohms Max Output: 400Wx4 CH
a gift from abroad on the occasion of my relative
PIONEER TS-W 308 D4 1400W 30 CM BASS 400 RMS double coil
is it compatible with each other and what is the rate of operation?
I do not want to buy a new amp and charge because I do not have a situation right now. PLEASE HELP !!!!
08.05.2020 17:59 # 2
Alicilik
Brother JBL has no d4 equivalent bass. Leaving der JBL pioneer emits stop. There are tons of differences.
All kinds of driving is not a problem.
08.05.2020 17:59 # 3
onuuuurrr
now I understand that if you connect the pioneer to the 2 channels of the amphitheater and the other 2 channels, just like jblde right now, you say that it will not be a problem and I will get more efficiency than jbl. Big smile glad this is a happy news thanks. So how much efficiency can I get from this pioneer?
08.05.2020 17:59 # 4
onuuuurrr
TMM DIR form event teacher Do you have any information about the last question I asked
08.05.2020 17:59 # 5
Feyribas
Let me explain the situation to you, my teacher ... It would be unnecessary to connect Ts 20 to Nafi and it would be a headache. But the amps in you are compatible with the 20s. You have written the values of Nafi but I don't think that you can get the rms "cea" value ... Maybe you can feed the jbl bass with the amplifier in your hand, but you may not get the sound you want ... You should feed it with an amp like 304 D double coil bass jbl 7001. Since it is a 304 D double coil, you can reduce the omage by 2 ohma with parallel connection and draw the maximum power from the amp and get good efficiency. Your luggage lock malfunctions ... :) Regards ...
