COMPARE HELP
08.05.2020 18:20 # 1
roland_garros
Guys, my tape recorder is sony right now, and it has around 230 zero, second hand 150tl, pioneer has a new tape, if i bought it, which one is better? I'm giving pioneer sub output zero 150 TL link can you help?
SONY CDX-GT620U : Elegant design with bright blue backlit information panel
DRIVE-S for uncompromising sound and greater durability of the CD drive
45x4W S-MOSFET amp delivers window-shaking power and reduced distortion
CD / CD-RW / mp3 / WMA / ATRAC (from USB only) / AAC playback
USB input for easy digital music playback
RCA SUB OUTPUT
13-segment LCD display for clear and readable playback information
Front AUX? Input for direct connection of your portable music player
EQ3 Stage II / DSO amp for up to 7 different modes and incredible playback
Digital Music Plus for extra sound clarity
3 pre-outs
PİONEER MVH-150UB
The sound system that I will put:
JBL GTO 6508C 16CM MID
JBL GTO 508C 13CM MID
JBL GT4-12 30CM SUB
XETEC 172.5 ANFI
08.05.2020 18:20 # 2
kursat3006
the price is really good. I bought the non-bt 200 lira a few months ago and everybody said good
08.05.2020 18:20 # 3
barishrocker
sony plays softer, gives clean sound. The pioneer brighter system is especially good for bass. both major units have 2 RCA outputs. In my opinion, if a change is to be made, take a main unit with 3 RCA outputs so that the change reaches its full purpose. because 5ch amps have 3 amp inputs.
08.05.2020 18:20 # 4
roland_garros
If there is a brand you recommend, can you write
08.05.2020 18:20 # 5
barishrocker
I do not master all models. but there may be 3 rca pre out writers in their features. What I know is the pioneer x7550, x8550, x9550 ... I know the deh x .... series, other than that, there are also 3 out pre ones.
08.05.2020 18:20 # 6
Alicilik
6000 series and above are three times but this can change. I would recommend 3 RCAs. It makes a difference. You can separate the bass and speakers and control them on the tape without bass control.
I have the same amp. A very powerful amplifier from the skin heats up quickly only if you load too much.
08.05.2020 18:20 # 7
Alicilik
You can look at the subject of my vehicle.
08.05.2020 18:20 # 8
barishrocker
ali shows that there is 2r in x6550. I think 6000 series is not included in 3rca class ..
08.05.2020 18:20 # 9
Alicilik
[QUOTE = barishrocker] ali shows that there is 2r in x6550. I think 6000 series is not included in 3rca class ..
They pulled 2 in the new series. I have 6550bt, I plugged it into the corsa. It was the most convenient bluetooth and mixtrax tape. He had 2 RCAs. But the old series was 4v 3rca in the 6350s.
Now you know, they get fln for mixtrax-bluetooth-hdradio rather than the tape output.
I know I bought 40050 TL and got 9350 3 years ago.
08.05.2020 18:20 # 10
barishrocker
It is true that I do not master the old models. But if the aim is to get strong sound, I recommend pioneer 3-4volt 3rca outputs. There are even those with 5-6.5volt options like 9600mp .. For example, your friend has sony 2volt 2rca output ..
