Combining the 307 control with opening and closing
08.05.2020 18:36 # 1
rzsrht
I took my friends car to the master because the remote control is not working. He struggled with synchronization, connected to the computer, updated his bsi software. it worked exactly 1 hour but it did not. when the car is connected to the computer, when the control presses the on / off buttons, the computer shows that the doors are closed and opened, but there is no reaction at the doors. there is no problem in the central system. that is, I insert the key and open and close it. but we couldn't operate the remote.
I stopped hoping for him now. this is what I really want to do. Kliksa saw a snap-on opening-closing system. this is the link.
http://www.kliksa.com/urun/modacar-acma-kapama-seti-sustali-anahtarli-34b006/901765771
If I put the chip inside my car key into the key in this product. If I put this box on my car, I will solve the problem of the doors, but will it close the windows like the original key by holding the lock key down ? I want to have a switch on and off that does what the original key does.
Is there anyone who has done this job before or is you doing it?
So now I want to open and close my vehicle remotely.
rzsrht 2014-06-12 15:29:51
08.05.2020 18:36 # 2
rzsrht
No one has a friends solution or will give it to the tafsuma?
08.05.2020 18:36 # 3
muro_60
You can hurt the doors, but you can't lift the windows. Look at the original again. Peugeot does not accept it. Take such things to another master.
08.05.2020 18:36 # 4
madblueblacksea
It doesn't look like anything nice to me. You are thinking of replacing the original system with a fitting system. I think think again. After all, the system you plan to appreciate is available in the vehicle. Trying to eliminate the fault is healthier. I know that you need a module to lift the windows, if there is no auto mode. If you want a snap wrench you can just change the cover
08.05.2020 18:36 # 5
okaNStarss
Do doors lock when they lock from inside? Does the door lock with the key? And if you are going to add another system, you can look at them with products that have both a door lock, an alarm and a glass module.
08.05.2020 18:36 # 6
rzsrht
It locks from the inside and the key from outside.
As I said, when it is connected to the computer, when we press the on and off buttons of the control, it transmits it to the brain, it appears to be closed on the computer screen, but the central lock system does not activate.
other friends say it makes sense to try to fix the fault. I was surprised by my napal, walla. Sometimes there are moments when I go to open the doors from one end of the car to the other. this makes me angry ..
08.05.2020 18:36 # 7
okaNStarss
Did you try to get a software update from the service? If there is no problem with the mechanics and it is working manually, I think you should go to the service and get a software update.
08.05.2020 18:36 # 8
rzsrht
He also updated the software. both times .. tried to introduce the key. recoded but it didn't work somehow ..
08.05.2020 18:36 # 9
ahmed206
If you have the opportunity to write the key as additional information here, do it once.
Insert and turn the ignition but do not operate
Press and hold the close button on the key for 10 seconds, then switch off the ignition.
