com2000 key ok, but i have a problem
08.05.2020 16:18 # 1
iamrasit
How to make it thanks to cuneytatay 's member (see: http://forum.peugeotturkey.com/forum_posts.asp?TID=16691&title=peugeot-206-yol-bilg Bilgisayar-com2000-tu- I did the com2000 key exactly as shown in the pictures. First of all, I would like to thank cuneytatay .
My vehicle has 206+ and single line display. Now that button is working, but it only shows the temperature-date to the press. (I guess it is a single line display.) & Nbsp; Now I want to have a 3-line display, I just bought my car and it is guaranteed, do I need to have this service done in the service so that the warranty does not deteriorate? I have a 2-year warranty and I don't want to be broken, frankly. I called the service screen, they said 380 TL + it will be crafted, of course.
What should I do? Will the trip computer be active on one line display? or should I get 3 lines of screen? Which ways should I follow to ensure the warranty does not deteriorate?
Thank you in advance.
08.05.2020 16:18 # 2
iamrasit
I am really curious what should I do? Does anybody know?
08.05.2020 16:18 # 3
There is no such thing as the warranty of the vehicle is broken, my friend. continues
08.05.2020 16:18 # 4
iamrasit
[QUOTE = HuseyinTurk] There is no such thing as the warranty of the vehicle is broken, my friend. The warranty of everything except the part you change continues [/ QUOTE]
I called the service from there and they transferred me there when I asked for the warranty, I got angry and hung up the phone. If it is like you said, if only the part I replaced is out of warranty, I will take the replacement out without thinking. Reviews
08.05.2020 16:18 # 5
The trip computer must first be turned on by connecting the trip computer to the peugeot planet 2000. If you have these processes done in the pug service, no problem & nbsp;
08.05.2020 16:18 # 6
metin
change the screen yourself. If something happens, when you go to the service, you can replace the old one (:
& nbsp;
because the screen is one line, even if you open it from the computer, it cannot show the other two lines because one line (: so you will change the screen first, then you will be active from the computer. < / DIV>
08.05.2020 16:18 # 7
iamrasit
By connecting the [QUOTE = berkekk] trip computer to the vehicle & nbsp; peugeot planet 2000, the trip computer must be turned on. If you have these operations done in the pug service, it won't be a problem & nbsp; [/ QUOTE]
I called the service and they said, the part you have replaced will be out of warranty and may be out of warranty for any defects that may occur due to that part. After all, an electronic piece warns me, be careful. what do you say?
08.05.2020 16:18 # 8
iamrasit
[QUOTE = text] change the screen yourself. If something happens, when you go to the service, you can replace the old one (:
& nbsp;
because the screen is one line, even if you open it from the computer, it cannot show the other two lines because one line (: so you will change the screen first and then you will be active from the computer. < / div> [/ QUOTE]
I think so, is it too difficult to disassemble and replace the screen?
08.05.2020 16:18 # 9
metin
yoo, how should it be done. so many friends have changed. so you are not the first one, I don't think there will be a problem.
08.05.2020 16:18 # 10
service exaggerates brother bro relax nothing will happen to your car I saw a lot & nbsp;
08.05.2020 16:18 # 11
iamrasit
[QUOTE = berkekk] service is exaggerating, brother, relax, nothing will happen to your car, I saw a lot & nbsp; [/ QUOTE]
[QUOTE = text] yoo, how should it be done. so many friends have changed. so you are not the first one, I don't think there will be a problem, if there was something like that, they would have stated that there was a problem with other friends, they enjoy it. thank you :)
08.05.2020 16:18 # 12
Şahin Peugeot
Original Spare Parts
0216 631 10 80
0216 631 18 12
0533 301 88 06
www.peugeotmarket.com
AUTO EFE
Peugeot & amp; Citroen
Out Spare Parts
0212 486 33 66
www.peugeotcikmacisi.com
www.cikma-parcaci.com
make it easy & nbsp;
08.05.2020 16:18 # 13
iamrasit
I called, unfortunately, did not have it. I found in Ömer Oto in Ostim / Ankara, second hand peugeot 307 screen said 100 lira. but I don't want to buy it without seeing it: /
08.05.2020 16:18 # 14
I want to do the on-board computer case, but they caused me a problem that the vehicle could be out of service. There is no need to open it in the service, but my vehicle is guaranteed in March so I will do this after March.
08.05.2020 16:18 # 15
loiz
For 206, after making this com2000 key and replacing the screen with 3 lines, do I need to activate something from the brain or can I get clear information if it works directly?
08.05.2020 16:18 # 16
It is not necessary to activate it for 206+ s in 2010 and above, ie new case :)). It activates automatically when you insert the line screen and press the key. It is actually already on but the key and screen that will activate it do not work because it is not in the car. It's just pegging the screen and selling it as more expensive as envy.
08.05.2020 16:18 # 17
[QUOTE = iamrasit] I called, unfortunately, did not have it. I found in Ömer Oto in Ostim / Ankara, second hand peugeot 307 screen said 100 lira. but I don't want to take it without seeing it: / I think [/ QUOTE]
my teacher 307's is fading. I have 307 mine is a pale sbah show and then the image is gone.
08.05.2020 16:18 # 18
[QUOTE = Bahadır32] It is not necessary to activate for 206+ in 2010 and above, ie the new case :) 3) It activates automatically when you insert the line screen and press the key. The same ecu is used in comfort and envy. Just plug the screen and sell it more expensive as envy peugeot. [/ QUOTE]
Bahadır brother acted fast.
206+ asked us . He made the necessary explanation.
Making a wiper arm on a single screen only allows you to see the degree. You don't have to lie down and press the display key.
It is under warranty in my vehicle, but I changed it. Because the warranty event varies from service to service. Hold the old one to sell, if you wear it. The 206 screens become ours. Although the trip computer was turned off in PP2000, I could see the data, but I still had it opened when I went to the service. Not much has changed. I even had a speed warning on it but they didn't open it because they were unnecessary. The language option was not available for some reason. If you find any 3 lines 206-206 + screen like this, get the screen event without missing the price. I bought one out of envy.
We would be more helpful if you updated your information. Apart from my brothers and siblings in the forum, you can ask me questions about 206+ without hesitation. > Alliance 2011-10-27 22:01:18
08.05.2020 16:18 # 19
lkr_yldz
[QUOTE = loiz] Do I need to activate something from the brain after I do this com2000 key and change the screen to 3 lines, or can I get clear information if it works directly? and you have to activate the trip computer
08.05.2020 16:18 # 20
lkr_yldz
[QUOTE = iamrasit] [QUOTE = text] change the screen yourself. If something happens, when you go to the service, you can replace the old one (:
& nbsp;
I think so, is it very difficult to disassemble and replace the screen?
changing the screen is very simple you unscrew the 2 torx screws so much
Page : / 2
