Com2000 Defective headlight turn signal arm solid
08.05.2020 19:30 # 1
bozlak
Friends, is it possible to disassemble and replace the com2000 headlight turn signal arm in the picture?
08.05.2020 19:30 # 2
Mesut48
I had the same problem, there was no guarantee when it was repaired,
At that time, I bought it from the forum sponsor at an affordable price.
I think it's complete
08.05.2020 19:30 # 3
bozlak
Hodja, a friend in the forum had a bounce, because his signal headlight arm gives a solid airbag error.
08.05.2020 19:30 # 4
Airbag is not a problem, I do not know how to assemble the arm. If you have more experienced friends in this field, send a message if you want, but you may need a good master who will get it done where you are.
08.05.2020 19:30 # 5
Mesut48
[QUOTE = Bozlak] Sir, there is a friend in the forum. Can't he push his solid arm on mine because his signal headlight arm gives a solid airbag error, or can't my airbag pass to him? [/ QUOTE]
Again, the event turns to repair, this time the airbag wrap will change, there is no guarantee again
but if there is a place that says I can do this job with guarantee, it may be useful to try
I did not risk, I changed it directly.
