com 2000 related question ....
08.05.2020 19:11 # 1
xmen
friends now i have completely replaced com 2000 in my car .. my car has headlight sensor and i can't turn it off from the signal lever. The headlight sensor is actively working now ... I say I need to reconnect it to the computer and activate it. when it gets dark, it comes into action immediately ... or is there another way to turn it off and on? I am waiting for your comments with friends who have knowledge about this subject ....
08.05.2020 19:11 # 2
206cc57
In my car it is like, I inserted the key, the battery light came on or I turned it one more click, then if I hold it I can activate or deactivate the headlight sensor.
08.05.2020 19:11 # 3
xmen
[QUOTE = 206cc57]
Thanks for your comment ... I found the solution while tampering with the road computer .. it can also be closed from there ...
08.05.2020 19:11 # 4
xmen
friends I want to ask a new question about com 2000 ... how can we tell if this com 2000 signal arms are esp` ...
08.05.2020 19:11 # 5
Canberk35
ESP has nothing to do with Com2000 arms, teacher. If your vehicle is 307 and the vehicle has ESP, the button is located to the right of the hazard warning flash button. It writes ESP OFF on it.
08.05.2020 19:11 # 6
xmen
thanks for your answer to canberk35 ... if you do a little research alone you will see that com 2000 arms have something to do with esp ... even says the service ...
08.05.2020 19:11 # 7
Canberk35
Frankly, I don't know what kind of intervention can be done in ESP with the signal or headlight arm in the 307s. If it is a system with ESP setting, I would say that maybe its settings are being made. However, it is not a system that can be adjusted. As I said, the ESP on and off key is located next to the four flasher keys. I don't know what the ESP has to do with the arms. But at least I can say that the key required to activate or deactivate ESP is not in the arms.
Photo: http://www.forum307.com/upload/vignettes/jeff.huit/089f9u0.jpg
08.05.2020 19:11 # 8
xmen
I already know the button next to the hazard warning flashers, and I have it in my car ... I just heard that it is related to esp sensor com 2000 in the service ...
http://www.ebay.fr/itm/PEUGEOT-307-avec-ESP-COM-2000-parfait-etat-ref-96651589xt-delphi-/271858255052?pt=LH_DefaultDomain_71&hash=item3f4c03c4cc what you mean .. .
08.05.2020 19:11 # 9
206cc57
Searching for com2000 repair shop in Istanbul.
The zero is very expensive, the second hand is risky and the luck business is not cheap. The repair is cheap and the luck business.
The double-painted stick. Blind devil says zero and get rid of it, but the small arm is almost half the minimum wage.
206cc57 2015-06-18 23:59:40
08.05.2020 19:11 # 10
Canberk35
[QUOTE = xmen] I already know the button next to the hazard warning flash and I have it in my vehicle ... I just heard it related to esp sensor com 2000 in the service ...
Yes, teacher, I have solved the situation now. I did a little research on foreign sites. There is an additional socket connected to the COM2000 in the 307s with ESP so that ESP can work effectively. The socket is on any arm, namely the signal arm, the wiper arm, etc. not. It's under the wheel. This socket measures the current angle of the steering wheel and corrects the vehicle accordingly. It is also very simple to find out if the COM2000 installed in your vehicle has an ESP socket. You will ensure that the vehicle slides from the front or from behind, so as not to endanger yourself - just in case. Smile If ESP comes into play and corrects the angle of the vehicle, COM2000 means it is ESP. If it is not already compatible, it will not be able to apply correction because it cannot measure the steering angle.
08.05.2020 19:11 # 11
xmen
[QUOTE = Canberk35] [QUOTE = xmen] I already know the button next to the hazard flasher and I have it in my car ... I just heard it is related to esp sensor com 2000 in the service ...
Canberk teacher now we could get along. Smile ..
