Cold air entering through the door trim
08.05.2020 21:29 # 1
kaan206
friends 206 cold air comes from where there are column holes in the front door trim
I removed the door plastic, there is no torn opening on the insulating paper attached to the door sheet
Could this air enter through the rain drain hole under the door and exit where the column is in the door? I couldn't see any other place to enter the door
Do you have a similar situation?
08.05.2020 21:29 # 2
sercan23
I have the same problem with me. I saw that my 206 gti car was not preserved when I removed the door trims on both doors.
08.05.2020 21:29 # 3
This is a situation that you encounter in many vehicles in the same segment, as friends are the vehicle b segment. Check your door seals in one. isolation makes a difference.
08.05.2020 21:29 # 4
kaan206
There is insulation on the inner sheet of the door, the seal is strong, there is additional insulation material on its own insulation material plus sound and heat insulation sponge. What more?
As I said, while the vehicle is on the move, the only place where air can enter into the door should be a different hole under the door, engineers should have made a different hole where the air entering from here can come out.
? Does it come cold through the hole of the column? 2020-03-23 09:42:46
08.05.2020 21:29 # 5
sercan23
if you solve the problem, will you inform me in one way or another, i am still undecided about how to solve it
08.05.2020 21:29 # 6
kaan206
You are going to buy and paste the brothers insulation material is very simple ...
08.05.2020 21:29 # 7
sercan23
If I put the insulation material, I guess you will continue again, I think you said, or if the air enters the water discharge place, it confuses my mind or sticking the material is 5-10 minutes stylish work, but if I close the holes, do I cut it with silicone
08.05.2020 21:29 # 8
kaan206
If there is no insulation material, excessive wind and cold will enter the car through the door, let the wind cool, even rainwater will enter, the door does not put the insulation material in vain, if you close the drain holes, the water inside the door will be filled, the water canister will be closed, those holes will not be closed ....
I talked to the service that they said it was normal to enter the wind so your information ...
You are very precise, I am looking
There is no certainty that you have to try and see, is there any certainty that we will go tomorrow?
kaan206 2020-03-24 18:49:36
08.05.2020 21:29 # 9
sercan23
As if the door was entrusted to God, I mean I would apply it as soon as possible and share the drum.
08.05.2020 21:29 # 10
kaan206
There are self-adhesive aluminum foil-style insulation materials, there is no need for silicone in koçtaş or building markets.
If you do not wear hopörlor, it will be more effective to close it with insulation material.
kaan206 2020-03-25 00:00:42
