COKK ACILLL
08.05.2020 18:30 # 1
renk1234
I opened a knuckle of blue smoke today, but I looked at the engine cooling water of the car, I was in shock, I was over the water, I put my finger on the black blade, the white was balck, the oil was superfluous, but the oil did not have any oil effect. emergency support
08.05.2020 18:30 # 2
outlaw
SORRY BUT THE OIL SEAL THAT YOU SEE IS MIXED TO THE RADIATOR WATER OIL ... Confused
08.05.2020 18:30 # 3
renk1234
But the oil does not stop in the stomach, I know what I do not need, now it bursts, is it safe to use it as a valve?
08.05.2020 18:30 # 4
tongucuk
better be better not to continue using it in this way.
08.05.2020 18:30 # 5
renk1234
I did not do it at the heat, how was the gasket burned or my morale was broken
SM
08.05.2020 18:30 # 6
renk1234
Well, when the gas was loaded into the gas, the blue smoke showed a little bit to the master. They said the injector valve.
08.05.2020 18:30 # 7
106fb
I had heard that the vehicle had brown antifreeze water, and when I asked for the service in light brown color in the engine water, they said it was the color of the antifreeze. If you are sure that you do not overheat and you do not have a problem with the engine, it is likely your death especially in traction.
