Coil malfunction
08.05.2020 21:28 # 1
medcvt
Friends in my system system, the misfire gas cutting problem is not very common, but we thought it was the first lpg problem. I thought the lpg system changed completely from the beginning, then I thought that this problem was not igniting and I replaced the coil with the sub-industry coil. What is the reason of the need to get the original coil? Or is there another problem that spoils the coil?
08.05.2020 21:28 # 2
littlenikksay
Have the spark plugs changed with the coil?
08.05.2020 21:28 # 3
medcvt
spark plugs did not change spark plugs had changed before
08.05.2020 21:28 # 4
ismailkaya
it would be better if you replace the spark plugs first, if there is an explosion sound coming from the exhaust, if it is misfire, you should check the spark plug coils and cables.
08.05.2020 21:28 # 5
medcvt
I changed the spark plugs, it was not a problem. After a long break, the coils changed.
08.05.2020 21:28 # 6
x571
Are LLpg injectors checked? Has the LPG been shut down and used as such? What is the result?
08.05.2020 21:28 # 7
medcvt
same problem in gasoline, no problem in lpg system
08.05.2020 21:28 # 8
x571
[QUOTE = medcvt] has the same problem with gasoline lpg system has no problem [/ QUOTE]
I assume that it bought a compatible coil. Because they sold me incompatible. If you changed the coil once, okay it will not break again.
In the case of coil failure, a sound sounds from the exhaust to the fork. As soon as you hit the gas, you want to go into 2nd, 3rd gear, knock.
The spark plugs also make knocks when the air conditioner is turned on, when climbing uphill, while the engine is on the load, when trouble occurs.
Does the vehicle do it while it is loaded? Is he the first to run? Is the engine hot cold?
No fault code in the vehicle? Maybe he is escaping from the rocker cover and escaping to the spark plugs. Maybe injectors are troubled. Go somewhere with the original program, maybe there is a problem with the sensors. Universal ones do not read exactly.
x571 2020-02-25 09:27:02
