Coil brand recommendation
08.05.2020 21:11 # 1
x571
there are many brands in the market. bland, hella, delphi, mga, gva, huco or something. which one to take? What is 300 when someone is 600?
let me update the subject
2002 306 1.6 100 bg gray socket valeo coil given by looking at the chassis number does not fit this vehicle. When inserted, the vehicle shifts slipping. it shakes enough to turn on the malfunctioning light on the cold engine and knocks in 2-3 gears if it moves. I thought they sent different products in the first one and bought it from another seller. it turned out the same. I bought my money and returned it because I got it from the internet.
The problem is because the ignition section is different. There is a picture on the subject. The difference is obvious when looking at the ignition section by removing the plastic end of the coil.
Code of the Product: 5970 A8
smooth running product delphi: ce20011- 12b1
x571 2019-04-08 11:56:22
08.05.2020 21:11 # 2
I recommend Delphi.
08.05.2020 21:11 # 3
x571
[QUOTE = sonerkyl] I recommend delphi. [/ QUOTE]
They also sell valeo under its original name, it is the most expensive. Around 600 pounds. Is there a difference with Delphi? Or is there any meaningful difference?
08.05.2020 21:11 # 4
there is no meaningful difference, i think i wore a 206 delphi, i had no problem. it was delphi from the original.
08.05.2020 21:11 # 5
x571
[QUOTE = sonerkyl] There is no meaningful difference, I think I had a delphi on my 206 cars, I had no problems. it was delphi from the original. [/ QUOTE]
I made an order by giving the chassis number as original but it is very different with what comes out. coming out of the yellow one. I guess they sent it wrong. can such things happen? also the external type is different
08.05.2020 21:11 # 6
My teacher later on, that type of parts revision is generally the same as the main structure, but some different situations may appear like that end part. We bought a flywheel set for a last friend's 307 vehicle valeo. The sachs from the vehicle were original, but there was no pressure or flywheel resemblance at all, but it was completely different but there was no assembly and no problems.
08.05.2020 21:11 # 7
talip206
Hodja, have you installed and tried the new one?
Well, I bought 100 lira second hand never used, there was no problem. Then, when there was a brain malfunction, I bought a brand new HELLUX for 150 TL because they said the coil was defective because of the masters. I think, unless it is made in china, it won't matter.
Delphi does a good job as price performance.
But I think you will not return the coil you bought and you will not lose it.
08.05.2020 21:11 # 8
x571
[QUOTE = sonerkyl] later on, that kind of parts revision is generally the same as the main structure, but some different situations may come across like that end. We bought a flywheel set for a last friend's 307 vehicle valeo. The sachs from the vehicle were original, but there was no pressure or flywheel resemblance at all, but it was completely different but there was no assembly and no problems. [/ QUOTE]
[QUOTE = talip206] Hodja have you installed a new one and tried it?
I assembled it, but the car started to work jerky, not going into 3rd gear. His sherry registration officially. I put on the old coil now. the malfunction lamp is on and has little taste. Even the most fabricated brand is now 250 liras.
08.05.2020 21:11 # 9
replace the spark plugs.
08.05.2020 21:11 # 10
talip206
Sir, if you sell the old one to letgo or the owner, your loss will decrease. It was sold according to the socket color in the coils. The gray socket is white socket and black socket. It was the gray socket that came out of you (the ends are yellow).
We also have a situation like this. There are simple springs in the tires at the end of the coil. If those springs and the tires at the end do not fit the spark plug heads, the jerk will tremble. If you don't control the springs.
If you are in Üsküdar, I would be helpful
08.05.2020 21:11 # 11
x571
[QUOTE = talip206] Sir, put the old one on letgo or the owner and you will lose your loss. It was sold according to the socket color in the coils. The gray socket is white socket and black socket. It was the gray socket that came out of you (the ends are yellow).
gray socket out of the vehicle, yellow end. The gray socket comes in again, but the tip is both gray and there is a hole in the middle.
Is there a trick to fit, what to pay attention to? Do we need to do something like aligning the springs with our hands? I carefully fit it into the holes, press it a little bit. I do it with my hand to make it sit right, but when the plastics are in place, it doesn't make much of it right.
Thank you very much for the offer :) I would come if I was in Istanbul, in Mersin.
x571 2019-03-27 23:00:28
08.05.2020 21:11 # 12
talip206
There is no particular attention, but sometimes those springs can be attached. Once installed, one end of the spark plug cannot touch the head. So he's kicking.
08.05.2020 21:11 # 13
x571
[QUOTE = talip206] There is no special attention, but sometimes those springs can be attached. Once installed, one end of the spark plug cannot touch the head. That's how it kicks. [/ QUOTE]
I solved the problem and updated the subject in the first message. the problem is that the piece sent is different. Because I bought 2 different products. There was no problem in delphi.
