Coil
08.05.2020 17:35 # 1
sezar206
Hello friends. My coil got water twice. The air filter accident has taken water, from there to the coil directly. & Nbsp;
Now it seems like it doesn't work very well. There is no problem in idling, but when I start the car, there is a smell of gasoline. There is an event that we call burning raw. For example, if I make bottom gas while driving in the 2nd gear with 20, the car will pile up first, shake it slightly and then jump off. I changed the spark plugs, we checked it the other day. Fuel is always where I get it. This problem has been around for a year and does not cause any problems. I think it burns a bit too much. & Nbsp;
If I change the coil? Could there be another reason?
08.05.2020 17:35 # 2
sezar206
08.05.2020 17:35 # 3
If too much water has entered, the pistons will be damaged, otherwise the water will become steam. If prbolem has been going on for a year, I think it is not due to water entering. Ask the ignition system starting from the simple.
08.05.2020 17:35 # 4
haakaannn
I also have a similar problem, I couldn't solve it, when the car was idling, when it was loaded on the gas, the cycle first falls, then the car gets gas. As you say, he piles up first and then picks up. but only when gas a & nbsp; is happening at the first press is no problem.
