clutch wire help
08.05.2020 14:52 # 1
montante
friends, I just joined you, I have a problem, I would be glad if you could help, 4 months, the gradient pressure plate was made 5 times the clutter wire breaks, the wire turns, and the wire balance knob breaks out of the knob. I would like to thank everyone for commenting friends.
08.05.2020 14:52 # 2
deniz_206
Disease of this clutch wire break in the 206's, I broke it 3 times.
08.05.2020 14:52 # 3
montante
My napcam teacher, there was a wire all over the house, why do I have something like this?
08.05.2020 14:52 # 4
ALX
Greetings!
Sometimes it happens in the 106s. Since the end of the wire is plastic, that piece was broken very often. I have researched in foreign forums, replace the plastic tip with a handmade metal master, who knows his job well, get rid of this problem. I don't know how accurate, I have to investigate ...
08.05.2020 14:52 # 5
montante
I bought it originally, my teacher, especially I bought it from the service.
08.05.2020 14:52 # 6
deniz_206
The kick-off nail may have changed the clutch set.
08.05.2020 14:52 # 7
montante
My friend, the print was changed to the pad, it has been 4 months. I just weren't able to wear my master. This is the only thing that comes to my mind.
08.05.2020 14:52 # 8
FTH
Luk, well, valeo da luk I did not have a problem for 1 year, no problem, I had an orge on the wire
08.05.2020 14:52 # 9
montante
teacher, there is Öznur Oto in the bursa, I bought 4 of them from the billiard nilkar, the room was broken so that the inn was original.
08.05.2020 14:52 # 10
FTH
Actually, if you go to the master wearing that pressure pad and tell them, it makes it better.
If necessary, no one can collect the money from the street again.
08.05.2020 14:52 # 11
montante
teacher, get this gearbox to master cira, I wonder if there is no problem here, I say the quality of the wire.
08.05.2020 14:52 # 12
montante
friends solved the problem when the press was attached to the pad while the master was attaching the crew to the crew, the crumb shifted the ball behind the press and the ball was broken, and it was 400 malls for me.
08.05.2020 14:52 # 13
FTH
Morning Eye ..
