CLUTCH TAKILIYO
08.05.2020 16:44 # 1
tuci
2005 1.4 HDI XR & nbsp; I have a vehicle when I press the clutch, it seems as if it is stuck to the end. Also, bedal sounds as if it was like a throat while pressing as if it were rusted. why is the solution doing this & nbsp;
08.05.2020 16:44 # 2
herry
can it really be attached to a mop =)
08.05.2020 16:44 # 3
There is a spring on the clutch pedal. Sound that may be coming from it. Reviews
08.05.2020 16:44 # 4
dukenukem82
I don't know the sound, but at some point my pedal was stuck on it, I was crashing. If it is not from the mat, a & nbsp; clutch & nbsp; & nbsp; look at the pad. :) dukenukem82 2012-05-02 08:35:01
08.05.2020 16:44 # 5
impertore
Spring on clutch pedal & nbsp; problem & nbsp; can ...
08.05.2020 16:44 # 6
ufuk91
What kind of incident is it that the first thing that happened to me was the first time that happened? -4481-99A to-19f420d90332etdefend is / huidhui.js? 0 = 0 & amp; 0 = 0 & amp; 0 = 0 ">
08.05.2020 16:44 # 7
Bugra
it is absolutely attached to the mop. I had the same problem. In sound it works wd40.
08.05.2020 16:44 # 8
sahin-peugeot
Probably the clutch wire may be faulty, it is better if you look at the master in a short time.
08.05.2020 16:44 # 9
erdi777
I had the same problem, it was making noise, I shook it, I did not go to the industry, I did not look at the industry, and it exploded in my hand: D I changed the complete clutch set before I see it as soon as possible ..
08.05.2020 16:44 # 10
ibrahim YILDIZAK
[QUOTE = sahin-peugeot] Probably the clutch wire may be faulty, it will be better if you look at the master in a short time if it breaks down [/ QUOTE] & nbsp;
I know as electronic after 2003 .
Correction: I mixed it with throttle.
ibrahim YILDIZAK 2012- 05-02 19:31:01
08.05.2020 16:44 # 11
ByHack
I mean, I wasn't a mop sufferer "LOL" & nbsp; anyway, while pressing the clutch or something like a rubbing-like vibration and then a grinding sound sounds like that. There may be such a problem from clutch ball. it was like that in mine :(
08.05.2020 16:44 # 12
tuci
Thank you for all your opinions, friends. We took care of the sound of the debris by lubricating the spring of the clutch with the spring on the pedal. there is no problem right now & nbsp;
08.05.2020 16:44 # 13
Cmoss06
Get well soon
