Clutch stiffness
08.05.2020 19:31 # 1
istsaao
I just joined your friends. My Peugeot 307 1.4 2004 car has no problem with the clutch hard clutch, but in the transition. Special service said around 650 TL press brake. Does it soften when it changes
08.05.2020 19:31 # 2
samet206
In other words, the prices are more or less for the pressure pad.
08.05.2020 19:31 # 3
istsaao
It seems to me tough like I am a clio reno doblo vw user like this 307 hard. He said this stiffness, he even said these are not hydraulic clutches.
08.05.2020 19:31 # 4
madblueblacksea
[QUOTE = istsaao] Either it seems hard to me. I am a clio reno doblo vw user before, this 307 is hard. He said this hardness, he even said that they are not hydraulic clutches [/ QUOTE]
Trying to find the truth by comparing not only different brands but even different models (such as 206 to 307), you are wrong. In my vehicle, the clutch is hard for me, but I thought the clutch wire was broken when I got out of my cousin renault fluence and got so soft when I got into my car Smile
08.05.2020 19:31 # 5
Efe-Pojo
Does debriyj hard ever change the pressure pad? Just do the clutch adjustment and replace the clutch wire.
08.05.2020 19:31 # 6
istsaao
As far as I know, there is no wire or setting status at 307 1.4.
08.05.2020 19:31 # 7
istsaao
That's why I even sell the car
08.05.2020 19:31 # 8
GokhaN
Since there is no wire in my 207 to change the hard clutch, but if you wear valeo's own production or luxury, the originals are hard because the room cannot soften much.
08.05.2020 19:31 # 9
istsaao
I mean, should I never handle this way?
Isn't there anything that happens in this case?
08.05.2020 19:31 # 10
teacher, my neighbor has 307 1.4 hdi, his clutch is hard so i think there is no problem, if there is no situation like the sound of a shaman, don't waste money. Maybe you opened a subject like this, you may have looked but I said I'll throw it again.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=21610
sonerkyl 2015-11-27 10:47:38
08.05.2020 19:31 # 11
istsaao
I examined that link but no one has come to a clear conclusion
my main concern is this:
Is there any change in the pressure pad set when the clutch is hard and become soft ????
08.05.2020 19:31 # 12
okan77
The 307 xt clutch pressure pad + ball + clutch fork (all org) had a noticeably softening when replacing it ... But it can only be helped from a distance without testing with the vehicle. :)
08.05.2020 19:31 # 13
Emask
2004 307XT Gasoline I just changed it. The clutch will definitely soften, I would recommend you to do this by researching if the vehicle has ever changed, it will be a problem in a short time.
08.05.2020 19:31 # 14
istsaao
I got it in 123 thousand, 135 thousand now
I don't know if there is change before
So how much are these changes
08.05.2020 19:31 # 15
If the £ 265 originally set https://www.peugeotturkiye.com/peugeot-307-14hdi-debriyaj-seti-156 debrijay fork changes slightly increases the amount of labor between TL 200-300 guess transmission oil felan etc. then it is likely to hold a figure of around 600-700
08.05.2020 19:31 # 16
istsaao
Guys, I have written the same thing before, sorry, but the peugeot 307 1.4 hdi users are sure to use this clutch, I want to clarify the soft soft event.
08.05.2020 19:31 # 17
istsaao
Friends no one reads the msge or you have no idea. 307 1.4 2004 anyone who knows in the forum
08.05.2020 19:31 # 18
Hodja, your messages are being read, friends who know why to read have already written their answers. Yes, I used it. 1.4 diesel is also correct for gasoline in clutch.
08.05.2020 19:31 # 19
Halil5759
My old vehicle was Hyundai Accent, the current 307 1.6 hits sounded a bit harsh compared to my other vehicle, but I will not take any action because there is no other problem.
08.05.2020 19:31 # 20
Gilan
Sa friends, I had 1.6 hdi 307sw available clutch tightening in me, it came to me too hard when I first got on, my pads accumulated and fuel consumption was around 7.2. I am afraid that I will take off the clutch while using the presentation. There is no problem when I press it. The only difference in this way is the consumption and traction changed tremendously.
Page : / 2
