Clutch Shiver
08.05.2020 20:47 # 1
kayaca
Why does the clutch vibrate, as is the topic of friends? I changed the clutch wire 1 hour ago, there was no problem, it started to vibrate on the road, it makes a sound, it makes a rattling throttle, goes to 3 4 revolutions, it rattles when I attack it. or is a wire connected to the clutch pedal?
08.05.2020 20:47 # 2
Whether it is on the shake clutch pedal or in the car, bro. I could not fully understand.
08.05.2020 20:47 # 3
kayaca
[QUOTE = sonerkyl] broke on the clutch pedal or in the car bro. I could not fully understand. [/ QUOTE]
the pedal also had tremors, we changed the clutch wire, the gears did not pass, we changed the clutch wire, it was like it would be fixed, 1 2 hours later, I started to do the same things again.
They said the car was shaking when they got up
08.05.2020 20:47 # 4
KILIC
Exactly the probability of being out of print axes is very high.
08.05.2020 20:47 # 5
kayaca
and the sum of the changed materials harmed me
08.05.2020 20:47 # 6
Except for the printing pad, other prices are suitable bro. Good luck now, brother. Get well with this.
08.05.2020 20:47 # 7
kayaca
[QUOTE = sonerkyl] Except for the press pad, other prices are affordable, bro. Good luck now, brother. Get well with this.
I said I would buy another piece of material if I did not go to buy it again.
08.05.2020 20:47 # 8
If my brother does it, I guess they may have caused the flywheel. I think the place is special service.
08.05.2020 20:47 # 9
kayaca
yes teacher I made it in private service
08.05.2020 20:47 # 10
I think you can bargain a little when you go.
08.05.2020 20:47 # 11
pejokoray
My car is automatic. The accelerator pedal was shaking, I changed the exhaust muffler, it improved. I know I should deal with your problem. Bid, this bill you sent is not a workmanship pejokoray 2018-02-27 18:15:32
