Clutch set replacement hk.
08.05.2020 19:54 # 1
tolga.onal
Friends hello my vehicle clutch plate is completely on them will be exhausted now a couple of questions, clutch linings if the Do we need to replace replacing the flywheel what would we do if necessary. (307 1.6 benzinli- moving flywheel) lining Second in çaktırma he heard a process do you think would be healthy I would be very happy if you helped anyone who tried it later.
08.05.2020 19:54 # 2
senalcay
The flywheel does not change. But the part called pressure (i.e. the other side of the pad is in contact) can be replaced if necessary. Your master will decide on this. The quality of the lining is not obvious, it may be necessary to change it again very early. It can be done in very old vehicles and if the parts cannot be found. The point to be considered is to purchase and renew the bearing separately if the set is not taken. Even if the bearing is good, a new one is installed because the same workmanship should not be repeated for a bearing.
08.05.2020 19:54 # 3
tolga.onal
So if I drive the car in such a short distance of about 2 weeks, does it harm other parts? I wonder if I encounter a problem
08.05.2020 19:54 # 4
Vefa
You will not meet my brother, after a mudded, it will be completely finished then I will not go even if you hit the gas.
08.05.2020 19:54 # 5
cnrx9004
You will stay somewhere you do not expect, I will change 307 1.6 petrol clutch set 149 tl I ordered from mapa
