Clutch set-fork-gear
08.05.2020 18:11 # 1
rhcpeppers
As friends broke the vehicle pressure is constantly broken. They opened and looked at the vehicle repair, the clutch set will change the fork gear will change. He said the amount of 1000 pounds is maniac. How much does this normally cost & nbsp; parts give me a way I will go crazy now I renew the print every 3 months
08.05.2020 18:11 # 2
Turgay_66
Get well soon, hoping that you will solve the problem as soon as possible.
08.05.2020 18:11 # 3
rhcpeppers
thank you
08.05.2020 18:11 # 4
rizeli_53
It is a different situation to be so often.
08.05.2020 18:11 # 5
samet206
The clutch set is originally a figure between 350-400 TL for the stone crack including craftsmanship, but since it is related to the gearbox in the light of the fork or something, this is normal.
08.05.2020 18:11 # 6
rhcpeppers
When I say my gearbox is relevant, my gearbox is removed
08.05.2020 18:11 # 7
samet206
[QUOTE = rhcpeppers] my gearbox is related when I say my gear is disassembled [/ QUOTE]
I do not know exactly about it but I do not think this is what is called the clutch fork. it is better to get a clear answer on this issue, but as I said, even those who experience this problem do not knock over the clutches without the clutch & nbsp; they may encounter situations such as excessive vibration, shaking, etc. I can not be able to repair it, but I changed the degradation recently, it was not much more than its price.
