clutch set changed but still stiff
08.05.2020 17:38 # 1
oz26
Friends greetings. It was the first time I had a pejo. My car 307 110 hp diesel, 2006 model. When I picked up the car 5 months ago, there was stiffness in the clutch but there was no intrusion in the clutch. I asked the service, they said there was no problem, but it started to disturb the traffic in the city. When I asked another service, they said that the clutch should be changed. When I repeat this in several special services, the clutch and flywheel set in Bursa nilkar changed. However, when the vehicle got out of service, the hardness in the clutch & nbsp; softened a little, but they say it is like cotton. it's still pretty hard. They told me to drive about 2000 km, I used it, but there is no change. I went to the service again, they say no problem. Can anyone help if anyone knows what could be the cause of this stiffness? Enjoyable rides & nbsp;
08.05.2020 17:38 # 2
oz26
So is this a chronic problem. Believe me, if I see a diesel 307, I will go to the left on the right and ask for permission from the owner and make a comparison.
08.05.2020 17:38 # 3
[QUOTE = oz26] So this is a chronic problem. Believe me, if I see a diesel 307, I will go to the left on the right and ask for permission from the owner and make a comparison. None.
from the set.
08.05.2020 17:38 # 4
Gokhan Cetin
There is 1.4h in the room, the room feels hard, according to the vehicles I ride
08.05.2020 17:38 # 5
emre_akdag
hardness can be chronic my friend, because after 2000 km, it is a new one that starts the pressure and knows the flywheel.
08.05.2020 17:38 # 6
qqyyxx
[QUOTE = onurazgin] [QUOTE = oz26] So is this a chronic problem? Believe me, if I see a diesel 307, I will go to the left on the right, ask the owner for a comparison and make a comparison. but 110's hard ... I couldn't drive any other car when I got used to & nbsp; "Smile". We have made muscle: D joke since the hard clutch has the vehicle + s. at least in my car, the slightest clutch problem has not occurred yet (the construction does not occur) but the reason is caused by the fixed flywheel. they send me a problem no problem .. unfortunately [/ QUOTE]
let's fix the 90's volant is fixed and its clutches are hard, 110 'have movable flywheel & nbsp; clutch is softer. & nbsp; If there is no softening, there is a possibility of a problem with the material used, how much have you changed. These are the parts that are & nbsp; supplier industry. & nbsp;
08.05.2020 17:38 # 7
impact
I don't know diesel, but I want to even try and stop someone in my car, as @oz26 says.
My friend had 206 diesel like his cotton. That means the 307s are in trouble.
08.05.2020 17:38 # 8
mranda
307 1.6 HDI is mine too, but it is not so hard. It seems to me like normal, but my friend has a Honda 2006 model room like cotton :) same way again my manager has a hyundai in him clutch cotton. Can we say chronic acep? I have 307 in my neighbor, but I have never looked at it.
08.05.2020 17:38 # 9
tellotello
If you stop and check me, you start to claim that your vehicle's clutch is like cotton. "Smile" Opportunistic services will replace it immediately, but it will guarantee the softening When I say "Are you ready?"
08.05.2020 17:38 # 10
howard
THERE IS 206HD FULL REVERSE IN MY ME TO OTHER VEHICLES MY SOFT :)
howard 2013-05-31 17:16:24
08.05.2020 17:38 # 11
oz26
The original clutch and flywheel set changed in the authorized service with a cost of 1550 TL. External pejo series gave 1200 TL price. But since the guys do not feel very comfortable, I preferred the authorized service.
08.05.2020 17:38 # 12
reality59
1.4 70 HP HDI 2004 model 307 I have the same problem, too, compared to other vehicles, it is very hard but there is no problem at the point of clutch.
08.05.2020 17:38 # 13
cey cey
I have 106 gti, the clutch is perfectly hard, I went to look at the service, they said normal, they said bole, they said bole one day, a gti coincided, I went down like a feather, I said it was not normal. There was a perfect change in the vehicle, now, like a tug, maybe there could be a problem with the clutch wire.
08.05.2020 17:38 # 14
oz26
none clutch hydraulic of master 307s. Maybe if it was a wire. not like that.
08.05.2020 17:38 # 15
muhoist
I also used 206 at 307, both of which are hard to peugeot when you get used to other vehicles than clutch hard
08.05.2020 17:38 # 16
uguur
The clutches of the 307s are hydraulically fabricated, so they are all the same 1.4 hdi xr, only 1.6s have a click softness, so don't compare to other vehicles.
08.05.2020 17:38 # 17
OguzhanKucuk61
206 SEDAN 1,4 75 hp gasoline car had incontinence and hardness. Clutch and ball were changed with Valeo brand set and as you said it was like 1-2 thousand km cotton. Then mine hardened very fast. It is not like before and it does not grasp above, but it is hard. If the solution to the problem is found, let us know :) :)
08.05.2020 17:38 # 18
ismailkaya
first, good luck & nbsp; 307 vehicles have different engine versions, best of all, find the engine version of your own vehicle, try it, try it for 7 years, I have been using the 2005 model 307 1.4 gasoline 90 hp, you do not know most features of your vehicle more, you will love it more as you know the feature. I say match the door of the mechanic, open a subject here, everyone conveys what they know. How many thousand km of vehicle did you get? & nbsp;
