Clutch Replacement
08.05.2020 19:33 # 1
ekenn
Hello friends. 2004 206 I have 1,4 gasoline. The printing pad is now finished :) I have to change. I looked at the clutch sets. If there are friends who change, which brand of clutch would they recommend? What happens to me in the total bidet cost. I would be grateful if you could help. Eken 2015-12-19 00:20:01
08.05.2020 19:33 # 2
Sercan Mungan
Hello teacher, I recommend you to use the original parts and I can tell you to check the status of the flywheel. You can get information from the forum sponsor.
08.05.2020 19:33 # 3
samet206
I recommend using the original parts in this regard, and I would recommend looking at the axles, axle seals, gearbox oil, gear stick, clutch wire and flywheel during the change, even if it is used without any tampering for many years. I guess he finds TL.
08.05.2020 19:33 # 4
hakao
I just replaced it, bought the original parts, and there were 500 things to do. If there is a place you trust the master depending on the agreement, make it there and it is an important barrier.
