Clutch remaining
08.05.2020 17:07 # 1
mrttkin
Friends first, good night. About 2 hours ago, I want to share with you the fault that happened to me. When I threw the car from 1 to 2, the clutch was stuck and I did not go to 2 right away. I pumped it a little bit. I waited, I pressed the starter again, this time a very subtle sound started to come under the hood. Then I left the car, I came.
I searched before I write here. Once again, he came to the press. When I took it to the master, the wire said that the oil will pass over time. It has never been since. Could it be rain for 2 days? Could it be rusted ??
My Car 206 1.4 HDI
mrttkin 2012-11-04 00:51:28
08.05.2020 17:07 # 2
Open the hood and see if the end of the gear stick is still in its slot. & Nbsp;
08.05.2020 17:07 # 3
FeverDog
Whether it was past, my friend, I had the same problem. In fact, while I was pulling my foot off the pedal shortly after the change, the pedal was stuck while the pedal was up, then it passed spontaneously. koliva, where can i see the bar you are talking about in the hood i want to check it
08.05.2020 17:07 # 4
[QUOTE = FeverDog] well, my friend, I had the same problem, the clutch ball was changed. In fact, while I was pulling my foot off the pedal shortly after the change, the pedal was stuck while the pedal was up, then it passed spontaneously. koliva, where can i see the bar you mentioned in the hood i want to check it too [/ QUOTE]
When you look towards the right rear of the engine, it is seen. Someone shifts inside, you look from top to bottom. You will see it move. If it does not, it means he has left. This is usually the problem. If the problem is not here anyway, it is necessary to resort to deeper and more expensive solutions.
08.05.2020 17:07 # 5
nkre51
debrage & nbsp; rope must be changed
as a workaround
the drain rope after lubrication after removal
08.05.2020 17:07 # 6
06OzGuR06
The same situation happened to me, a problem that you can meet when the clutch system is stranded. Around 40 TL. If workmanship is included, the problem is solved for a total of 60 TL. And your driving pleasure increases
08.05.2020 17:07 # 7
sansasyon61
Well, is the creaking sound coming from the clutter sometimes it is related to the wire :)
08.05.2020 17:07 # 8
mrttkin
I showed it to a master today, in fact, the master came, said the rope will change, but when he heard the sound coming from the starter press, he said the ball was directly pressed to the ball, and 500 liras would cost me.
08.05.2020 17:07 # 9
cgty86
The master's fix is correct .. & nbsp;
08.05.2020 17:07 # 10
mrttkin
thank you for your interest tomorrow, the industry road seemed to me :)
