clutch problem
08.05.2020 18:36 # 1
griaslan
Hello, every time I press the clutch without opening the contact, there is a noise called ciyk.
08.05.2020 18:36 # 2
griaslan
I guess nobody knows the answer
08.05.2020 18:36 # 3
IBRAHIM ASIL
I think it comes from my car too, I would say from the pedal, but like it comes from the outside, the km can be from the press pad.
08.05.2020 18:36 # 4
samet206
Clutch ball is your problem. After the sound increases and you start to bother you, you can fall on it.
08.05.2020 18:36 # 5
ByHack
[QUOTE = samet206] Clutch ball problem. You can fall on it after the sound increases and starts to bother you.
Thumbs Up I agree with a friend, there will be an increase in volume in a short time. I say take care of the problem without further ado. Unfortunately, do not cause larger problems in the future, it is also useful to remove the pressure pad while changing the ball.
