Clutch Problem
08.05.2020 17:44 # 1
myvzklc
Friends have a clutch problem in my vehicle that the vehicle gear has become so soft that in a moment, as if there is a gap, the car is yelling in 1st gear, but I do not get up, but it is difficult to remove, but I did not come back to the mechanic in the morning, the bidet clutch set will change until the evening, he said he will check the transmission ropes, the bidet clutch set will change. Does anyone have experience on the subject, I wonder what exactly is the problem? Dead
08.05.2020 17:44 # 2
emre koksal
I think the press pad needs to be replaced ...
If you think it sounds like clattering sounds, you should add oil ...
08.05.2020 17:44 # 3
SDYMZ
print balata teacher is nothing but a total of 700 TL I think
08.05.2020 17:44 # 4
myvzklc
I talked to my mechanic, the repair pad set is 250 TL, the transmission ropes are around 350 TL, and the handwheel has changed at 200, 800 TL. I guess it's a costly car Ouch
08.05.2020 17:44 # 5
myvzklc
Ulutaş Automotive, a master I have known for a long time in old garages, looks at all the cars of our house
08.05.2020 17:44 # 6
samet206
It happened to me recently, I think I think from the press pad to your problem, but even though I have the problem of the press pad, there is no gap in the gear, just like you said, the car is moving more difficult than before, it has lost its streak except there is no gap.
08.05.2020 17:44 # 7
myvzklc
My teacher was 350 TL due to the transmission rope in the gap in the gear. Dead
08.05.2020 17:44 # 8
samet206
[QUOTE = myvzklc] In the gap in the gear, the price of the teacher was due to the transmission rope 350 TL Dead [/ QUOTE]
I understand, my teacher was quite costly to get past.
08.05.2020 17:44 # 9
myvzklc
When I first bought it, I spent 700 TL for rot heads, exhaust, discs and so on. Bid this output is now I spent a lot of money.
08.05.2020 17:44 # 10
bysarsinti
You can get the clutch set from our sponsor 50 TL will be your problem. The problem you mentioned is something that will be solved with the clutch set. If the master makes a beer discount, you will close your job to 400 TL.
