clutch problem
08.05.2020 14:13 # 1
TheEchoes
The clutch of my vehicle has become very hard lately, it started to vibrate during the departures. last night yesterday when I was getting up on the flat road or half clutch was not remembered, suddenly the pedal fell to the bottom, the car stopped, I thought the clutch wire was broken (it had happened to me before) but I proved the pedal with my foot and lifted it back to the old way. While driving at low speed in the 1st and 2nd gears after the first take-off, it sounds as if it is like a chain sound. I wonder if what could be the problem? Meanwhile, the car has 99 diesel partners
theechoes 2010-04-15 01:42:28
08.05.2020 14:13 # 2
TheEchoes
I guess nobody knows Sırıtma
08.05.2020 14:13 # 3
ibrahim YILDIZAK
I have similar problems with the printing pad looks like problems.
08.05.2020 14:13 # 4
pressure pad .. nothing else I shifted both the gear was relaxed and the traction became super.
08.05.2020 14:13 # 5
haruncoskun
synchromentors can damage gear gears later if you continue to appreciate that the pressure pad is unlikely to change
08.05.2020 14:13 # 6
deniz_206
The pressure is very good when the pad is definitely changed, the clutch pedal is soft.
08.05.2020 14:13 # 7
TheEchoes
I showed it to 3 different masters, all of them said press brake, then one of them asked 400 tl 350, the other asked 300 tl, all of them said we would get an average of 100 tl of work, the rest was clutch set + oil change, but the difference of 100 tl confused me. Does it cost 100 TL from brand to brand in spare parts? or which brand is better? Is there a master you know in Istanbul?
theechoes 2010-04-17 15:55:50
08.05.2020 14:13 # 8
yusufcilgin
take the clutch set yourself, go to the master and give it workmanship :)
08.05.2020 14:13 # 9
Eyup Duygun
of course, it does not matter whether you use mobil1 oil, use oil that is not known, use the oil filter of the original, use the mirror, use the mirror, if you are close to the Istanbul Anatolian side, if you are nearby, I will be able to get rid of the material, as the friends say, you can take it as a master.
08.05.2020 14:13 # 10
FTH
Valeo Al sister
08.05.2020 14:13 # 11
BuRCaK
Where do you live in Istanbul? If you are on the Anatolian side, I would say go to the master I have been going to Örnek neighborhood for 4 years. I have no inference, it just works very clean and its price is affordable. He does solid work and does not give up. If you want, I can give you a private message. There is the old Göztepe inspection station.
08.05.2020 14:13 # 12
TheEchoes
I am on the European side, but I always go to the Anatolian side due to my job. I was talking about a peugeot citroen service on the libadiye street of the old inspection station, maybe we are talking about the same place. It makes more sense to buy the piece myself, yes a few people suggested a brand but the price was too expensive for me and let me see the valeo
08.05.2020 14:13 # 13
BuRCaK
Not on libadiye street, brother. It is not ethical to advertise here. So if you want, I can give you private information.
08.05.2020 14:13 # 14
TheEchoes
ok give private information Gülme also advertise if master is well. I met such masters .. you have to hang it on the ceiling, you understood it Sırıtma
08.05.2020 14:13 # 15
ibrahim YILDIZAK
:)) I will change it too, but I can not find time.
08.05.2020 14:13 # 16
mrb dude it is a little late but i will give you an idea as a pejo mechanic if you change the clutch wire the wire is elongated because the sound coming from the engine will not be a problem, because the vehicle is xud 1.9 engine, a small distortion in advance adjustment solves a fine adjustment work. Sleepy
08.05.2020 14:13 # 17
TheEchoes
I was suspicious of the first clutch wire. I change the first wire, I am not looking after.
