clutch pressure pad
08.05.2020 15:01 # 1
ask307
Hello everyone. friends my car peugeot 307 1.4 hdi 2005 model 95000 km I have never changed the clutch pressure pad of my car. It makes tremors at take-off and started to consume a bit more fuel. If I changed the pressure to the pad, it would have helped fuel and the car's traction. Thanks to everyone in advance.
08.05.2020 15:01 # 2
xMEGANx
I don't know if it was fuel in traction
08.05.2020 15:01 # 3
you see the benefits in the traction, you see the benefits in the fuel very little, if you want to check the filters I am sure they are old because they increase the fuel consumption
08.05.2020 15:01 # 4
xMEGANx
replace the injectors and filters, you will see the difference in fuel, but the pressure does not change the pad so much.
08.05.2020 15:01 # 5
ask307
I already have the oil maintained at an authorized service in 10000. I replace the air filter every 5000. but I have not changed the diesel filter. injectors changed at 70000 km because of the aqueous diesel oil pump was repaired.
08.05.2020 15:01 # 6
adilpeugeot
The shudder event ends when the clutch changes, and the car burns too much in difficulty. It decreases in the problem. But, as the friends say, the filters on diesel vehicles are very important and they need to be replaced on time.
08.05.2020 15:01 # 7
furkan
Are you sure that no embankments have changed until 95000 km as clutch
08.05.2020 15:01 # 8
the_beKKo
we changed around 85 thousand
08.05.2020 15:01 # 9
xMEGANx
brother, my car has changed to 90 thousand pressure pads
08.05.2020 15:01 # 10
ask307
I haven't really changed it since zero km I have been using it myself, but there is no shifting or something, there is only tremor, low traction and much fuel, and the grip is above. So what changed friends could I write about their complaints.
08.05.2020 15:01 # 11
if the clutch is up, it can happen at the end of the clutch.
08.05.2020 15:01 # 12
ask307
above and rigid clutch. something caught my attention today, I don't know, the clutch car is shouting at 2500 revolutions in 2nd gear, but not at the desired speed. I guess I will change it towards summer
08.05.2020 15:01 # 13
marasov
like me shouting in the car but not going so 3500-4000 revs still wants gear in 5 gear 1.9 wonder why diesel partner
08.05.2020 15:01 # 14
kasirga85
In our parner, the clutch was quite soft and the grip was nice at first, now it feels strange when pressing on the clutch, and a little above, do we need to change the clutch set?
