Clutch Point
08.05.2020 21:21 # 1
selcukcolak6161
Hello friends. We replaced the 2004 partner's clutch wire but it grips very high. Is there a place where we can arrange this, or is it necessary to go to the master
08.05.2020 21:21 # 2
omerb
selçuk bey, there were lock nuts where the rope was attached. At the end of the rope. I know that you're adjusting from there. In fact, at first you had to measure and mark the pedal position when removing it. To align the new rope when installed.
08.05.2020 21:21 # 3
selcukcolak6161
The problem is that I never understand the engine part 🤔 Where exactly in the engine is this wire
08.05.2020 21:21 # 4
omerb
I don't know the location of the party. I looked at the web, but I couldn't see it exactly. Follow the clutch pedal. It's already a short rope. Something 50-100 cm. Helen is at the back of the pedal. You may not be able to see it from the top.
Take a look. I think if you can't see it, take it to your master.
08.05.2020 21:21 # 5
selcukcolak6161
I found it, but I couldn't figure out how to make the adjustment. I think the way of the master appeared
08.05.2020 21:21 # 6
omerb
I know it's a bolted section. Just like adjusting the brake levers of the bikes. You do it by adjusting the rope tension. You loosen those bolts and loosen them incorrectly, or you squeeze them. You adjust your sensitivity accordingly. If you can, you can try. Or you may not even bother
08.05.2020 21:21 # 7
selcukcolak6161
Thank you
