Clutch pedal problem.
08.05.2020 19:32 # 1
hakao
When I press the clutch pedal to the end it seems to be stuck for a short time and comes back. I searched a little clearly, they said it could be clutch wire. There is no problem with gear changes, no kidnapping on slopes. He said he was just doing it sometimes, at first, he was hanging on the doormat. How much workmanship costs estimated wires 60 something around 70 TL. Could it be from another problem? Thanks in advance.
08.05.2020 19:32 # 2
If there is no problem with the gear shifts, there is a problem with the clutch wire. Have a check the same problem happened to me in my focus vehicle. I think they do not want a lot of labor, they want a fee between 50-100 TL. You need to show the vehicle and get a price from a few places.
08.05.2020 19:32 # 3
hakao
There is a master that I take hard, they just look at the peugeot Citroën vehicles. Thanks for the answer
08.05.2020 19:32 # 4
You are welcome hakan, as you said, there is no problem in the gear shifts in the vehicle, the only way in its performance is to it. I guess the spring on the clutch wire must have lost its property.
08.05.2020 19:32 # 5
samet206
I even came across the price of 150-200 for this job, and finally I got somewhere from 130 TL. I don't have anything to do. I would definitely not recommend trying to run the clutch wire broken vehicle.
08.05.2020 19:32 # 6
hakao
I will have it tomorrow. Let's see what will come out.
08.05.2020 19:32 # 7
hakao
My brother has been using the car for a while. Thanks for your answers
08.05.2020 19:32 # 8
I hope your teacher will solve your problem by changing the pressure pad. Your comments on the result are welcome.
08.05.2020 19:32 # 9
hakao
My brother, who bought the car, did not have a chance to try it, but he was troubled by a few old pipes that came out old and they did what they had to do when they were opened. I do not know when the money has been stuck, but I did not know when it changed before I passed 15000. In the case of a single problem, let's get into trouble and trouble.
08.05.2020 19:32 # 10
samet206
Replacing the press brake is costly but use it, as you said, no accident, these are somehow done again.
samet206 2015-12-10 00:22:52
08.05.2020 19:32 # 11
hakao
I am asking a lot of questions in the meantime, after a long time I got into my car and it was always in my car. The printing pad has just changed. When we left, we opened the heating system, worked for a while, smelled like a burnt smell, we got scared, we pulled the hood to the right, we sniffed everywhere, there was no smell, no oil on the engine, no matter if they burned. We set off again, turned on the air conditioner, operated it for a while, the smell made very little, then the smell was cut. Did the pollen filter do this, while the master made it clean, the master said it was cleaner, he just grabbed it and cleaned it. Either you sell me or we disagree with my daughter
08.05.2020 19:32 # 12
xmen
Yav that burnt smell comes from my vehicle .. I couldn't find a chance to look at it .. I wonder why .. I did not get any smell when I opened the hood.
08.05.2020 19:32 # 13
samet206
We can not understand it without looking at the vehicle, it can make it from any different situation, but I do not think it is from the pollen filter, it makes the most bad smell, the pollen filter does not create a burning smell. Also, this type of paper filters should be pollen filter or air filter. it is not cleaning for the filters.
samet206 2015-12-10 23:20:49
