Clutch Pedal Knock
08.05.2020 21:25 # 1
bsr15
Hello friends,
I just joined you. 206+ 1.4 HDI (2012) I wanted to ask a few problems about my vehicle. My first problem is a beginning problem. That is, when I press the clutch and change the gear or disengage, when I pull my foot out of the clutch, when the clutch passes the clutch point and comes into the clutch play, it stays stuck and hits the remaining 1 cm part by hitting it. As if it's not a problem with the gearbox, gear, clutch. No other sound, no sound from the engine. I think it was caused by the pedal. Do you think it's a normal situation?
Another problem is that the engine temperature of my 206+ vehicle generally runs at 70 degrees. When I compress it on ramps or in the city, it goes up to 80-90 degrees, but as soon as I stop compressing it goes down to 70 degrees again. Is this the case for you?
08.05.2020 21:25 # 2
omerb
Hello there. The clutch cable may be stuck. I say look at a master.
08.05.2020 21:25 # 3
bsr15
Actually, the first day I noticed the sound, I took it to the master. He looked at it, but could not say anything clear. Since I live in a small place, I do not have many alternatives for the master. So I wanted to consult the forum. I did not shoot the video I linked, but the problem of my vehicle is similar. In addition to the video, in my car, 1 of every 3 presses on the clutch is stuck where the click sound in the video comes from my clutch. He puts himself up when he poke with my foot. If anyone knows, I will go to the master again according to him.
08.05.2020 21:25 # 4
ismailkaya
Is there a switch at the bottom of the clutch?
